macbook A2918, orange light off when shut off
  • mosfetratus
    Sure Not
    • Feb 2019
    • 174
    • Resistron
    When i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
    Works with battery and charges, but when i shut off i get this problem.
    It had liquid spill. Board has no corrosion, keyboard is working, power button and fingerprint is working, but angle sensor is gone - so i removed it. It worked fine till this day.
  • mosfetratus
    Sure Not
    • Feb 2019
    • 174
    • Resistron
    Apple silicon only resets by pressing power button for about 10 seconds. Such a noob. But still i get this problem and discovered an anomaly on the board. So i guess this component was semi alive and i got some lucky resets.
    Voltage goes from from 1.2 to 5V in random values.
    Photo shows highlighted components. Need second opinion, i'm a hobbyist.
    Can't find any info about this component
    5302 t34 cw​
    • mon2
      • Dec 2019
      • 14672
      Cannot find a schematic in my database for this logic board.
      Share side view pics of this '5302' marked part. They may be mosfets.
      5302 mosfet - Google Search
      • mosfetratus
        Sure Not
        • Feb 2019
        • 174
        • Resistron
        Measured voltage on caps before that component - color green. Solid 5.18V.
        • mosfetratus
          Sure Not
          • Feb 2019
          • 174
          • Resistron
          cant edit previous post to add image
          • mon2
            • Dec 2019
            • 14672
            The parts with the 5302 markings are mosfets.
            https://www.infineon.com/dgdl/Infine...53561b58dc1ec3
            • mosfetratus
              Sure Not
              • Feb 2019
              • 174
              • Resistron
              the look like AONE36196
              • mosfetratus
                Sure Not
                • Feb 2019
                • 174
                • Resistron
                https://www.vishay.com/docs/62055/sizf5302dt.pdf
                it looks like sw pins are getting random voltage if the design is the same, so likely mosfet is not the problem. I found other places with random voltage.
                • mosfetratus
                  Sure Not
                  • Feb 2019
                  • 174
                  • Resistron
                  found two DC - DC converters - https://www.ti.com/lit/ds/symlink/tps62130.pdf
                  one spits out 1V to 5V garbage, other is no output, maybe system needs to be fully on.
                  Cannot trace out connection to where it goes when disconnected from power supply, i get megaohms.
                  • mosfetratus
                    Sure Not
                    • Feb 2019
                    • 174
                    • Resistron
                    removed the chip, turned out clock was bad - pin 7, voltage goes random, dont have scope for proper analysis. Now im lost. Still get random voltage on that mosfet and on some other parts of the board.
                    • mosfetratus
                      Sure Not
                      • Feb 2019
                      • 174
                      • Resistron
                      noticed that pros using usb C device to measure voltage, etc.
                      so bought one. Maybe someone will tell some pointers by watching at these results.
                      • mon2
                        • Dec 2019
                        • 14672
                        The 5 volts is a power on default voltage and the board is drawing ~57 mA which is an extremely low current draw. The boards usually communicate with the power adapter over the CCx pins on the type C connector and negotiate a 20V PD contract from the power adapter. It is possible that you have a defective CCx pin due to an ESD event.
                        Power down -> rotate the adapter power head by 180 degrees and then insert onto the type C paddle board. This process will then mate the other half of the type C connector circuits. Still the same voltage / current draw?
                        • mosfetratus
                          Sure Not
                          • Feb 2019
                          • 174
                          • Resistron
                          recently this laptop had a strange behavior. When shut off charger would go off - no light, and mac won't react to power button. But trackpad is still clickable. So i hold power button to reset, trackpad no longer clicks, still couldn't boot afterwards. Sometimes it worked correctly, power on when charger is connected, etc.
                          Laptop had a soft drink spill, luckily keyboard is still working, power button and touch id too. Only angle sensors is reporting screen always closed so i removed it. On the board i found only 1 spot with liquid damage. Laptop worked for a month or so then started to misbehave. For some time power button reset worked until it didn't. At some random times it worked.
                          And usb C worked fine, because i had adapter to connect regular USB HDD
