Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
  • joshAU
    • Oct 2008
    • 35
    Hi all.
    This notebook was showing no signs of life.
    I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
    However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
    If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
    I tried replacing the MOSFET with a new one, but again no voltage on the resistors above.
    With PQW1 removed, pads 5,6&7 show a short to ground (zero ohms).
    I assume that either the GPU, a memory chip, or one of the capacitors on the rear side of the PCB near the memory chips, and the GPU, is shorted.
    They are all on the +1.35VSDGPU rail.
    I am wary to inject more than 1 volt into this rail, so I am having difficulty isolating the cause of the short to ground.
    If I inject exactly 1V after the MOSFET, it draws approximately 1.3A, yet nothing gets warm anywhere on that rail, which makes me think it may be the GPU.
    The schematics and boardview were from here (thanks to aico60):
    https://www.badcaps.net/forum/troubl...atic-boardview
    I've tried removing a few large capacitors, (PCW9, PCW10 & PCW52), and visually inspected all the smaller 0402 & 0201 capacitors.
    Any suggestions of what to try?
    Is the GPU dead?
    If so, can it be disabled and instead just use the integrated GPU in the i7-12650H CPU?
    I had a search of the forums, and was able to get the schematics and boardview files, thank you, but apart from one post, I was not able to find out much more information.
    Thanks for any help you can provide.
  • piernov
    • Jan 2016
    • 4436
    • France
    Shorted MOSFET on VRAM power rail very often means all VRAM ICs + GPU are dead.
    • joshAU
      • Oct 2008
      • 35
      Thanks piernov, I appreciate your advice.
      I was hoping it was not the GPU, but was suspecting that it might be.
      Thank you.
      • joshAU
        • Oct 2008
        • 35
        I removed the Mosfet PQW1 and tested booting using the CPU's GPU.
        Unit powers on and boots using Intel GPU integrated in the CPU.
        Tests fine, and customer is happy.
        Thanks again.
        • Nagy Daniel
          Lowest possible resistance on laptop motherboard rail - Guide Table request
          by Nagy Daniel
          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
          So, I generated a table with AI so I can...
          03-04-2025, 08:24 AM
        • Victor Moreira Silva
          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
          by Victor Moreira Silva
          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
          Well, my decice specs are the following:
          Model: Acer Nitro 5 AN517-54-55T5
          CPU: Intel Core i5-11400H
          GPU: NVIDIA GeForce GTX 1650
          Motherboard: GH51G LA-L181P Rev:1c
          The symptom:
          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
          05-26-2025, 10:49 AM
        • lefetylorant
          Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
          by lefetylorant
          Hello Everyone,
          Long story short, I got this unit for very cheap.
          I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
          I've performed some measurements:
          - 20V rail perfectly...
          09-14-2023, 05:05 AM
        • bimole
          Weird behavior on 3.3V rail of a CORSAIR CX600
          by bimole
          A colleague gave me an apparently ill CORSAIR CX600.
          He told me that he heard a banging noise, and smelt the magic smoke.
          After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
          I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
          It's another story on the 3.3V rail...
          I have some devices to test deeply PSUs (scope, AC source, electronic load)...
          02-13-2025, 04:49 AM
        • nagkiller
          Asus Geforce Cerberus GTX1050TI-O4G-DIS short circuit in the FBVDDQ rail
          by nagkiller
          Hello everyone!
          This grafic card came for repair, but when I connected it to the motherboard, the board would not start (short circuit in the 12V rail).
          After removing some PLs to isolate the short in the 12V rail, I got to PML1/PML2, according to the BoardView reference.
          Even injecting a voltage of 1V0 and a current of 3A in the FBVDDQ rail, for example, the voltage drops to 0V20 and none of the components heat up.
          The attached boardview file is very similar to this grafic card, which I am basing the repair on.
          I would like some...
          05-10-2025, 09:19 AM
