Is the only way to resest/delete the BIOS passwort removing and reprogramming the bios chip? Or is there any other easier method?
					HP ProBook 640 G3 BIOS Passwort reset
 Most Elitedesk models the BIOS IC is accessible when the bottom cover is removed. You need to use a suitable SOIC8 clip (like a Pomona 5250) in conjunction with a half decent programmer (I use a SVOD3) to do the dump.
 Use RCUnlocker by Rhetorical Cheese to remove the password from the dump, and write it back. Then you just need to reset all security defaults to factory in BIOS setup.
 I just did 11 x 430 G4's y'day without disassembly.Comment
 There`s a 640 G3 bios request thread -> https://www.badcaps.net/forum/troubl...g3-bios-neededMost Elitedesk models the BIOS IC is accessible when the bottom cover is removed. You need to use a suitable SOIC8 clip (like a Pomona 5250) in conjunction with a half decent programmer (I use a SVOD3) to do the dump.
 Two of the posted requests have a different type of chip W25Q128BV WSON8 , MX25L12805D SOP16Comment
 WSON8 huh? Well can't use the clip then. The Elitebooks I've seen with that chip do have pads on the PCB that you can connect with pogo pins.
 Don't know what the 640 G3 is like to pull apart, but some Elitebook models are a major PITA to pull apart just to do a BIOS IC. Any suggestions on a half decent Pogo pin clip?Comment
			Hello,😇😇😇
 I need help unlocking the BIOS password on my HP ProBook 11 G2 laptop.
 🔧 Model: HP ProBook 11 G2
 📦 Serial Number: 8CG72478MY
 🆔 UUID: 6F5ED686-5532-11E7-A2E2-911C6404E011
 🔒 BIOS Status: Locked with password
 The laptop is no longer under warranty and HP refused to help me.
 I’m looking for a custom SMC.bin file.
 I don't have a CH341A programmer, so it's difficult for me to provide a BIOS file.
 Thanks a lot for your help!🙏🙏🙏...-
							Channel: BIOS Requests ONLY!
			by tokoneHello, please help to unlock bios password for HP Probook 455 G7, atached 2 roms for two flash chips.
 S/N: 5CD0442ZFN
 ProdID: 255V2ES#AKD
 Motheboard model: X9M
 Thanks...-
			by YG007Hello... Where do I start. I have 2 questions/scenarios that might bring this laptop back to life, so here it goes!
 I have this laptop (Asus UX52VS) where I was flashing the BIOS to it and it froze during the process. I didn't have a reliable BIOS chip programmer at the time (It was a CH341A USB Programmer from Amazon where it took hours just to get the clamp on the chip and then every time I read, it gave me different results/corruption, and never would pass the verify test as no 2 reads were the same data), so I brought it to a shop. They had it for almost 2 months, but during...
			by piratiHello everyone,
 I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
			by FaissalDZHi everyone.
 I have an HP ProBook 5330m with bios password.
 and I need help to unlock this password.
 I already try RCUnlocker tool
 Please help me.
 Serial: CNF1400VLB
 Product: LG723EA#ABF...-
 01-20-2025, 09:57 AM
- Loading...
