HP ProBook 640 G3 BIOS Passwort reset
  • noobart
    • May 2024
    Is the only way to resest/delete the BIOS passwort removing and reprogramming the bios chip? Or is there any other easier method?
  • Fraheeba
    • Dec 2018
    • 9
    Unfortunately, you have to remove, clear, and flash the BIOS chip with the appropriate image without the password.
    • noobart
      • May 2024
      Thanks, I'll try that...
      • reformatt
        • Feb 2020
        • 1406
        Most Elitedesk models the BIOS IC is accessible when the bottom cover is removed. You need to use a suitable SOIC8 clip (like a Pomona 5250) in conjunction with a half decent programmer (I use a SVOD3) to do the dump.
        Use RCUnlocker by Rhetorical Cheese to remove the password from the dump, and write it back. Then you just need to reset all security defaults to factory in BIOS setup.
        I just did 11 x 430 G4's y'day without disassembly.
          • 20807
          There`s a 640 G3 bios request thread -> https://www.badcaps.net/forum/troubl...g3-bios-needed
          Two of the posted requests have a different type of chip W25Q128BV WSON8 , MX25L12805D SOP16​
            • 20807
            I`ll bet he gets a CH341A or EZP****
            • reformatt
              • Feb 2020
              • 1406
              WSON8 huh? Well can't use the clip then. The Elitebooks I've seen with that chip do have pads on the PCB that you can connect with pogo pins.
              Don't know what the 640 G3 is like to pull apart, but some Elitebook models are a major PITA to pull apart just to do a BIOS IC. Any suggestions on a half decent Pogo pin clip?
              • Soumana Sanou
                “HP ProBook 11 G2 BIOS password reset request – Need SMC.bin
                by Soumana Sanou
                Hello,😇😇😇
                I need help unlocking the BIOS password on my HP ProBook 11 G2 laptop.
                🔧 Model: HP ProBook 11 G2
                📦 Serial Number: 8CG72478MY
                🆔 UUID: 6F5ED686-5532-11E7-A2E2-911C6404E011
                🔒 BIOS Status: Locked with password
                The laptop is no longer under warranty and HP refused to help me.
                I’m looking for a custom SMC.bin file.
                I don't have a CH341A programmer, so it's difficult for me to provide a BIOS file.
                Thanks a lot for your help!🙏🙏🙏...
                06-17-2025, 04:04 PM
              • YG007
                Asus BIOS How To Reset To Default Settings?
                by YG007
                Hello... Where do I start. I have 2 questions/scenarios that might bring this laptop back to life, so here it goes!
                I have this laptop (Asus UX52VS) where I was flashing the BIOS to it and it froze during the process. I didn't have a reliable BIOS chip programmer at the time (It was a CH341A USB Programmer from Amazon where it took hours just to get the clamp on the chip and then every time I read, it gave me different results/corruption, and never would pass the verify test as no 2 reads were the same data), so I brought it to a shop. They had it for almost 2 months, but during...
                06-05-2023, 08:22 PM
              • FaissalDZ
                Probook 5330m bios password reset
                by FaissalDZ
                Hi everyone.
                I have an HP ProBook 5330m with bios password.
                and I need help to unlock this password.
                I already try RCUnlocker tool
                Please help me.
                Serial: CNF1400VLB
                Product: LG723EA#ABF...
                01-20-2025, 09:57 AM
              • Vesko356
                by Vesko356
                08-11-2023, 03:27 AM
              • llek100
                HP EliteDesk 800 G4 35W DM Desktop Mini PC - not posting after BIOS reset attempt
                by llek100
                Hello, sorry for the long post, I just wanted to include any details that might help.
                A bit of backstory - I currently have 5 of these MiniPCs - I got them for very cheap from Ebay. All of these PCs are BIOS administrator password locked without their drives.
                I also got a G3 large tower, that I could reset the password of fine just using a header and a button on the motherboard.
                So I thought that I could do the same with the G4 MiniPCs, oh how wrong I was.
                First of all, I stumbled upon a tutorial, that apparently showed a BIOS password reset procedure - where I basically...
                09-18-2024, 09:15 AM
