MSI MS-15811 need resistor value
  • duranayar
    • Feb 2014
    • 11
    • ankara
    Hello. If anyone has it and can measure 2 resistors next to the battery integrated circuit, I would be very grateful.
  • Bonzas
    • 472
    • Indonesia
    what ic that you unsoldered ?
    • duranayar
      • Feb 2014
      • 11
      • ankara
      bq24780
      • tronitas46
        • Aug 2022
        • 10
        hi! I just stumbled across your post, I have the same motherboard with a different problem (well, almost the same, I have a MS-15811 ver 2.1) unfortunately there doesn't seems to be any schematic available, but! I desoldered and checked the resistors you needed and I have their values, the first one seems to be a shunt (I'm reading around 0.1ohm with my DMM and 0.0050 with my shorty with display) so I marked it 0.01 because I'm not 100% sure but I don't think it really matter, and the second one I'm reading 433k, hope it helps!!
        • TinkerTron
          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
          by TinkerTron
          Hey everyone,
          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
          Instead, here's what's been bugging me so far:
          The schematic...
          03-06-2025, 02:03 PM
        • artvandalai
          What resistor ohm will work better to repair this waterpik?
          by artvandalai
          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
          01-05-2025, 04:10 PM
        • flat-earther
          Hoover FM216LI cordless vacuum refuses to charge
          by flat-earther
          I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
          I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
          5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
          So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
          06-06-2025, 03:14 AM
        • chth96
          Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
          by chth96
          I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
          Since then, This AC/DC adaptor have been out of order.
          But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
          After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
          And Is there any possibility that it will suddenly explode as well as to be out...
          12-03-2023, 04:40 AM
        • badcap111
          Xiaomi mi 9T missing resistor
          by badcap111
          Hi, while trying to replace a broken screen connector on the motherboard, I knocked off a resistor next to the connector, and the resistor vanished. I have tried to find out the value of the resistor by looking at the schematics, but I cannot find the value. The ID of the resistor, or what you should call it, is R6400.
          I don't know if the resistor is necessary for the phone to function, and the connector is still not soldered on to motherboard. I have contacted Xiaomi and asked them if they know the value, but they want a proof of purchase, which I don't have.
          Is...
          08-07-2023, 10:42 AM
