Acer e5-553 battery not detected error
  • ahmarzo
    • Mar 2015
    • 171
    • india
    Have laptop motherboard da0zabmb6e0 rev e showing battery not detected problem.while checking have
    Pin 3 - 3v
    Pin 4 - 3 v
    Pin 5 without battery 3 v with battery connected 0v
    Pin 6- 0.56v
    Pin 7&8 - 8.44v
    Have tried new battery and changed bq737
    When BATT Detect SW is pressed pin5 voltage goes to 0v
    Have traced pin 3 and pin 4 to the it8987e.
  • mon2
    • 14512
    Confirm that the series resistors @ PR56 and PR57 are ok = ~ 100 ohms each.
    Is the battery compatible with this unit? Have you tested with another known good battery?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      BQ737
      01.Measure resistance between ACN/ACP & SRP/SRN pins (no power connected)
      02.ACOK/ACDET/REGN voltage
      03.Voltage on Source/Gate/Drain of dc-in fets.
      • ahmarzo
        • Mar 2015
        • 171
        • india
        pr56 and 56 are 100 ohms confirmed
        resistance between acn and acp 0 ohms and srp an srn is 1.8 mega ohms
        acok -0v,acdet is 2.8v, regn is 6v
        voltage on dc in source 19.4v,gate 8.3v and drain 19v
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Resistance between SRP/SRN should be few ohms and not mega ohms. This indicates problem. Check the resistor connected to SRN/SRP pins and match with schematic. The battery CLR is Ok or burnt? Meter in diode mode-check continuity between SRN/SRP pins of charger IC to Battery CLR.
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • Ado02
            Acer SF314-41 battery not detected
            by Ado02
            I am working on a Acer SF314-41 laptop where the battery is not detected.
            The laptop works off the charger and the battery but it's not charging or showing the battery in Windows.
            Charger IC: BQ24781
            BATPRES - 0v With Battery and 3v Without when the charger is plugged in
            SDA - 3.2v
            SCL - 3.2v
            Battery Connector:
            BT+ 7.2V
            BI 0v
            BAT_IN#_1 0v
            BATA_SCL_1 3.2v
            BATA_SDA_1 3.2v
            Update: Brand New Battery Installed Prior To Any Measurements Were Taken...
            09-13-2023, 07:00 AM
          • DenK
            Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
            by DenK
            Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
            1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
            12-06-2024, 01:29 AM
          • mrkmpn
            Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
            by mrkmpn
            Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
            This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
            03-13-2024, 01:54 PM
          • survivalbloke
            Acer Predator Helios 300 - will not power up if battery is CONNECTED
            by survivalbloke
            This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
            06-25-2025, 12:20 PM
