Acer SF314-41 battery not detected
  • Ado02
    • Jul 2021
    • 100
    I am working on a Acer SF314-41 laptop where the battery is not detected.
    The laptop works off the charger and the battery but it's not charging or showing the battery in Windows.
    Charger IC: BQ24781
    BATPRES - 0v With Battery and 3v Without when the charger is plugged in
    SDA - 3.2v
    SCL - 3.2v
    Battery Connector:
    BT+ 7.2V
    BI 0v
    BAT_IN#_1 0v
    BATA_SCL_1 3.2v
    BATA_SDA_1 3.2v
    Update: Brand New Battery Installed Prior To Any Measurements Were Taken
    Where to look next?
    Mod Edit - Link to schematic https://www.badcaps.net/forum/showthread.php?t=117526
    Reminder: rules and organization of this section - https://www.badcaps.net/forum/showthread.php?t=117483
    Last edited by Vesko356; 09-13-2023, 12:40 PM. Reason: Attached schematic removed and replaced with link.
  • mon2
    • 14677
    Re: Acer SF314-41 battery not detected
    Test with another known good battery (Amazon?).
    • Ado02
      • Jul 2021
      • 100
      Sorry, I forgot to mention - I installed a brand-new battery.
      • mon2
        • 14677
        BAT_IN# (battery connector) should remain LOW as long as the battery is connected. Respectively, this signal BAT_IN# = PWR_CHG_BATPRES# = BATPRES# (pin 15) on the charger IC.
        Again, the charger IC @ BATPRES# should remain low as long as the battery is attached. If this pin #15 on PU4403 goes logic HIGH (3v3) then the battery is considered to be absent.
        • Ado02
          • Jul 2021
          • 100
          BAT_IN#_1 is 3.26v when the battery is disconnected and Pin 15 on Charger IC is also 3.26v. When the battery is connected it drops to 0.300v.
          I hope this helps.
          • mon2
            • 14677
            Remove all power. Measure the resistance between pins 19 & 20 (SRN & SRP).
            Measure directly at the charger IC PU4403.
            • Ado02
              • Jul 2021
              • 100
              21.0 ohm
              • mon2
                • 14677
                The current loop circuit resistance is ok.
                Fault may be with the 2*DCin mosfets. Remove all power. Measure the resistance across each of the DCin mosfets (often the 2nd one can be defective).
                Measure:
                source (1-2-3) & drain (5-6-7-8)
                source (1-2-3) & gate (4)
                gate (4) & drain (5-6-7-8)
                Post each measurement.
                • Ado02
                  • Jul 2021
                  • 100
                  PU4408
                  1-2-3 & 5-6-7-8 / 4.7 Mohms
                  1-2-4 & 4 / 3.78 Mohms
                  4 & 5-6-7-8 / 6.10 Mohms
                  PU4401
                  1-2-3 & 5-6-7-8 / 4.9 Mohms
                  4 & 5-6-7-8 /5.72 Mohms
                  • Ado02
                    • Jul 2021
                    • 100
                    SOLVED:
                    Ordered another brand-new battery and this time everything works as it should.
                      NVDC charger configuration...
                      11-05-2024, 03:28 PM
                    • DenK
                      Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
                      by DenK
                      Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
                      1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
                      12-06-2024, 01:29 AM
                      ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                      Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                      The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                      for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                      Narrow VDC applications where the system power source is
                      either the battery pack or the regulated output of the charger.
                      This makes the max voltage to the system equal to the max
                      battery voltage instead of the max adapter voltage. Operating
                      at lower system voltage can improve...
                      11-05-2024, 04:43 PM
                    • flat-earther
                      how to prevent a connected charger from draining battery when not charging?
                      by flat-earther
                      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                      So the battery is backfeeding the charger and being drained.
                      How can I prevent...
                      08-07-2025, 01:04 PM
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
