Lenovo L340-15IRH fg541/fg741 nm-c362 rev 1.0 No power
  • tommy97
    • Mar 2023
    • 163
    • United Kingdom
    i've got for repair Lenovo L340-15IRH fg541/fg741 nm-c362 rev 1.0, laptop have instant short 20v 0.20amp draw, lv5083a goes to 100degree, i've removed 1 shorted cap next to the IC and short still remain, from look of it short comes from legs 16-25, i can't find what this IC i believe is 3/5V regulator?
    First mosfets normal 20v Source and drain and Gate 25v
  • mon2
    • Dec 2019
    • 14631
    Can you confirm this part #? Unable to locate it in my schematic.
    • tommy97
      • Mar 2023
      • 163
      • United Kingdom
      Lenovo LV5083A 6KU35 looks that this is the same component: https://www.aliexpress.com/item/1005002465864417.html
      • mon2
        • Dec 2019
        • 14631
        Measure the resistance to ground of the 2 inductors (PL****) to the left side of this regulator.
        • tommy97
          • Mar 2023
          • 163
          • United Kingdom
          PL3502 7Ohm
          PL3501 1.6k Ohm
          • mon2
            • Dec 2019
            • 14631
            Flux and carefully remove the solder blob at PJ3504. Do not power up without this blob.
            Measure the resistance to ground again at the inductors. Post the measurement.
            • tommy97
              • Mar 2023
              • 163
              • United Kingdom
              PL3502 About 60k Ohm (slightly going up)
              PL3501 1.6k Ohm​
              • mon2
                • Dec 2019
                • 14631
                Proceed to test the resistance to ground AFTER the solder blob pad. You have isolated the inductor and this PU401 by Lenovo and suspecting that it will no longer heat up as the shorted condition is removed. TBD.
                At this time, your short is on the consumer side of the +5ALW power rail. Confirm it with the resistance check.
                Would you have an adjustable power supply available for voltage injection? It will need to be set to 1 volt (not higher, to be safe) and 3-5A. For injection AFTER this removed solder short blob.
                • tommy97
                  • Mar 2023
                  • 163
                  • United Kingdom
                  After injecting 1V it does draw 0.01AMP and Lenovo IC does get a litle bit hot in the same place.
                  • mon2
                    • Dec 2019
                    • 14631
                    Measure the resistance to ground on each side of the pcb pads for PJ3504. One side was shorted. This last tested site is not shorting. Post the measurements. No power during these tests.
                    • tommy97
                      • Mar 2023
                      • 163
                      • United Kingdom
                      Bottom side (edge of the board) 6.5Ohm (Is the one where after applying 1v IC gets hot), top side 60kOhm
                      • mon2
                        • Dec 2019
                        • 14631
                        Can you post a pic of where and what is getting hot?
                        • tommy97
                          • Mar 2023
                          • 163
                          • United Kingdom
                          Left side of the IC
                          • madjid911
                            • Dec 2016
                            • 404
                            • France
                            Originally posted by tommy97
                            Left side of the IC
                            I had the same problem, it heated in the same place but in reality it was the micro controller which was short
                            • caprigtx
                              • Mar 2022
                              • 63
                              • Netherlands
                              I have tha same problem , can you tell me where the micro controller is on the bord(still learning)
                              • huzo
                                Lenovo IdeaPad L340-15IRH FG541 FG741 NM-C362 water damage no GPU power
                                by huzo
                                The board is FG541 FG741 NM-C362, and the laptop was water damaged,but not too much.
                                I cleaned the board and laptop was blinking white light , 3.3V and 5V were present, CPU had no power, i analyzed the startup sequence and found that there is no VCCSA on the CPU, i traced it to the PU2901 and found the Vin pin 47 had no input, resistor 2Mohm was burned OL, replaced that and now the CPU is getting hot and i get the keyboard backlight now and fans spin, but still blinking white light and no image on the screen, but now the GPU is cold, and i remember when i first took the board the
                                07-04-2024, 04:06 AM
                              • coasterghost
                                Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                by coasterghost
                                For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                System Hardware:
                                Processor: AMD Ryzen 7 PRO 5850U
                                Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                09-08-2025, 10:46 PM
                              • newjan
                                lenovo l340 fg541/fg741 nm-c361 rev 1
                                by newjan
                                bower led blinking can any one help me to fix my bios
                                lenovo l340 fg541/fg741 nm-c361 rev 1...
                                09-02-2021, 12:20 PM
                              • abdoelhosseiny@aol.com
                                Lenovo IdeaPad L340-15IRH FG541 FG741 NM-C362 Schematic
                                by abdoelhosseiny@aol.com
                                Please I need Lenovo L340-15IRH (81LK) FG541 FG741 NM-C362 Schematic
                                03-17-2021, 10:38 PM
                                Lenovo 3000 Series Schematic
                                Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                3000 C100 laptop with Braille keyboard
                                Lenovo 3000 C
                                C100, C200 - 15-inch XGA screen
                                Lenovo 3000 N
                                N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                N500 - 15.4 inch screen.
                                Lenovo 3000 V
                                V100, V200 - 12.1-inch WXGA models
                                Lenovo 3000 G
                                G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                10-04-2024, 06:05 AM
