Beginner question - Hot RT9513 chip
  • mon2
    • Dec 2019
    • 14001
    Let me post the G4 BV in the schematic section.
    Posted here:
    HP G6-1241sa - DA0R13MB6E0 REV E - Boardview - Badcaps
    While I go and cut the grass / weeds, review the soldering of this IC. Review the resistance to ground of the inductors as per our posts and use the BV to locate the linked inductors. If there is a shorted part on the rail, this part can heat up but it really should have turned OFF to prevent this situation.
    • Darren Hibbert
      • 102
      Originally posted by mon2
      Are you sure the chip is RT9513?
      See your other thread here:
      What is this chip? EQ ED B1Y - Badcaps
      Update:
      Study the G4 schematic and review PU3 = RT8223.
      This dual regulator creates the +3VS5 and the +5VS5 rails.
      With no power to the board, measure the resistance to ground of PL20 inductor (either side is ok).
      With no power to the board, measure the resistance to ground of PL23 inductor (either side is ok).
      Post each measurement.
      Does your board like the one below?
      Click image for larger version Name:	PL20.png Views:	0 Size:	183.8 KB ID:	3256572
      Click image for larger version Name:	pl23.png Views:	0 Size:	181.8 KB ID:	3256573
      PL20 = 3.0 ohms
      PL23 = 0.4 ohms
      • Darren Hibbert
        • 102
        PU3 chip
        Resistance to ground -
        Pin 1 = 110.5K
        Pin 2 = 6.08K
        Pin 3 = 110.4K
        Pin 4 = 4.07K
        Pin 5 = 4.07K
        Pin 6 = 130.6K
        Pin 7 = 0.5
        Pin 8 = 1.3
        Pin 9 = O.L
        Pin 10 = 2.3
        Pin 11 = 0004
        Pin 12 = 6.2M
        Pin 13 = O.L
        Pin 14 = 0002
        Pin 15 = 0001
        Pin 16 = 0.9M
        Pin 17 = 327K
        Pin 18 = 13.9M
        Pin 19 = 6.14M
        Pin 20 = 3.1
        Pin 21 = 6.1
        Pin 22 = O.L
        Pin 23 = 9.93K
        Pin 24 = 3.2
        Hope this means something to you as it means zilch to me!!!!
        • Darren Hibbert
          • 102
          • mon2
            • Dec 2019
            • 14001
            We are hunting for shorted output rails and you appear to have a few:
            Pin 11 = 0004
            Pin 20 = 3.1
            Pin 21 = 6.1
            Remove all power. Meter in resistance mode.
            Measure the resistance across the mosfet pins for the following parts:
            PQ51
            PQ46 ; low side mosfet
            PQ26
            PQ21 ; low side mosfet
            Measure:
            source (1-2-3) & drain (5-6-7-8) ; pick any of the pins from the shared pins
            source (1-2-3) & gate (4)
            drain (4) & drain (5-6-7-8)
            Post each measurement. We are hunting for a shorted mosfet which will probably be on the low side (the mosfet that goes to ground for each leg).
            Do not power up during these tests. From the shared low resistance measurements, both rails are shorting.​
            • Darren Hibbert
              • 102
              PQ51 - Source & Drain = 5.6M and dropping
              Source & Gate = 001.5
              Drain & Drain = 3.800M
              PQ46 - Source & Drain = 003.1
              Source & Gate = 2.500M
              Drain & Drain = 2.500M
              PQ26 - Source & Drain = 2.500M
              Source & Gate = 001.0
              Drain & Drain = 3.200M
              PQ21 - Source & Drain = 000.4
              Source & Gate = 6.30M
              Drain & Drain = 6.30M
              • mon2
                • Dec 2019
                • 14001
                You are missing a few units of measurement in the posted values.
                Flux and remove PQ21 off the board. Do not power up without these parts.
                Measure the resistance to ground again with pq21 on the board.
                Also concerned about PQ46 but need to know the units of measurement.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  #28
                  Remove the chip PU3 and then measure resistance to GND again on coil PL20/23. Next measure resistance to GND on pin8/17/16 of PU3(pcb pads).
                  PS:DONT PUT POWER WHILE PU3 IS NOT SOLDERED.
                  • acedogblast
                    by acedogblast
                    11-02-2024, 05:13 PM
                    by SMDFlea
                    Bad...
                    09-02-2021, 04:40 PM
                  • BMCappelletti
                    Asus Chromebox CN62 - wrong chip put on BIOS reader
                    by BMCappelletti
                    Long story short:
                    - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                    - gave the computer to his son a couple years later
                    - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                    - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                    (seems like the story was not that short)
                    He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                    01-08-2025, 07:27 PM
                  • Troystain
                    Help EZP2023+ updated chip database for w25q256jveq?
                    by Troystain
                    Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                    I need to add w25q256jveq chip but I do not know what data should I type.
                    I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                    The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                    11-25-2024, 12:53 AM
                  • inck243
                    Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                    by inck243
                    Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                    The BIOS...
                    07-25-2024, 09:17 AM
