Beginner question - Hot RT9513 chip
  • Darren Hibbert
    • 102
    Hi.
    My Hp G6 laptop died while using it.
    I opened it up and used a thermal camera on it to see if anything was getting hot. The RT9513 chip (EQ ED B1Y) which is supposedly a battery charger ic was getting hot. I ordered a new one and replaced it but its still red hot. Where should I look next?
  • Darren Hibbert
    • 102
    I have no idea how to identify this chip or what it does. Can anyone help?
    • mon2
      • 14001
      RT8223MZQW
      High Efficiency, Main Power Supply Controller for Notebook Computer (richtek.com)
      • mon2
        • 14001
        Remove all power. Meter in resistance mode. Measure the resistance to ground of each and every pin on this device. Be sure of your soldering of this component; be sure that pin # 1 of the replacement matches the original; confirm the resistance of each and every pin to be sure there is no short.
          • 20656
          Originally posted by Darren Hibbert
          Hi.
          Post a link to the schematic if its available -> https://www.badcaps.net/forum/troubl...r-s-guidelines
          • Darren Hibbert
            • 102
            No schematic available. da0r13mb6e0 rev e
            • mon2
              • 14001
              Are you sure the chip is RT9513?
              See your other thread here:
              What is this chip? EQ ED B1Y - Badcaps
              Update:
              Study the G4 schematic and review PU3 = RT8223.
              This dual regulator creates the +3VS5 and the +5VS5 rails.
              With no power to the board, measure the resistance to ground of PL20 inductor (either side is ok).
              With no power to the board, measure the resistance to ground of PL23 inductor (either side is ok).
              Post each measurement.
              Does your board like the one below?
              Click image for larger version  Name:	PL20.png Views:	0 Size:	183.8 KB ID:	3256572
              Click image for larger version  Name:	pl23.png Views:	0 Size:	181.8 KB ID:	3256573
              • Darren Hibbert
                • 102
                Yeah looks like I replaced it with the wrong chip.
                • Darren Hibbert
                  • 102
                  Strange. I purchased this from eBay with the same code but it says it's an RT9513.
                  https://www.ebay.co.uk/itm/125556477...mis&media=COPY
                  • Darren Hibbert
                    • 102
                    • mon2
                      • 14001
                      Here is the datasheet for the RT9513:
                      Linear Single Cell Li-Ion Battery Charger IC (richtek.com)
                      At best, the Ebay listing is referencing the wrong part from Richtek. Is this part still getting hot? If yes, continue to review the other thread you have started to review the resistance to ground of each created rail by this controller. Either way, this is not a RT9513.
                      • mon2
                        • 14001
                        The schematic and BV pics are not from the exact board as yours. These are from the G4 model which appears to use the same controller @ PU3. Share pics of your board for this region.
                        If there is a need, can post the BV file I have for the G4 for your review. Is the layout the same as yours for these parts?
                        • Darren Hibbert
                          • 102
                          It's still getting hot. I will do the resistance thing with the old chip.
                          I will contact the eBay seller.
                          Thank you very much for your help. Just wish I had a schematic.
                          • Darren Hibbert
                            • 102
                            That looks like the same board. Photos attached. Can you send me that schematic please?
                            Obviously this picture has the new (wrong) chip on itClick image for larger version
ID:	3256585 Click image for larger version
ID:	3256586 Click image for larger version
                            • mon2
                              • 14001
                              Review the other thread, your board may be close enough to the G4 schematic to perform the repair. From these few readings, the vendor is probably mistaken on naming this as RT9513 in the Ebay listing. Which part did you receive exactly? Are the topside markings the same as the original? If you have 'EQ' then you should have the correct replacement part.
                              The heating of the part is probably due to a heavier than normal load on this component. For this reason, let us continue in the other thread.
                              • mon2
                                • 14001
                                Good. We now have a reference that can help us proceed. See attached. First concern is the orientation of pin # 1 of this boardview of PU3 on the G4 board and compare it to yours. Let me check against the datasheet.
                                Update - you have soldered it correctly with pin # 1 oriented like the BV.
                                Click image for larger version  Name:	PU3_top_view.png Views:	0 Size:	111.0 KB ID:	3256594
                                • Darren Hibbert
                                  • 102
                                  The laptop suddenly shut down one day and was completely dead. I opened it up, connected the power jack and that chip lit up like a Christmas tree under the thermal cam. I took the chip off and ordered the new one. Fitted it and it still gets red hot when connecting the power. Laptop will not start.
                                  • mon2
                                    • 14001
                                    See attached. From the angles of the pic, concerned if you are really soldering the part to the pads. Suggest to flux each side of this IC. Then take a soldering iron tip and drag it with melted solder on your tip across these pads. The iron should not be too hot that it nukes the pads(!) = bad. But hot enough that the liquid solder will wick up the gaps that are visible. You want to flood the solder between the PCB pads and each IC contact. If you short anything, flux and touch the pads again till you draw out the excess solder. In the end, you want good joints.
                                    • Darren Hibbert
                                      • 102
                                      Ok thanks
                                      • Darren Hibbert
                                        • 102
                                        Do you have the BV and schematic I can download to look at with boardviewer?
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                          Common SPI bios chip programming Questions and Answers
                                          by SMDFlea
                                          Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                                          A: If you can`t read from it how do you expect to write to it ?.
                                          Q: Why is my bios chip unreadable ?.
                                          A: The programmer is faulty or has a worn or broken zif socket.
                                          The USB cable is frayed,connector pins worn or some other physical damage.
                                          Not enough amperage or voltage to power the programmer properly.
                                          Bad...
                                          09-02-2021, 04:40 PM
                                        • BMCappelletti
                                          Asus Chromebox CN62 - wrong chip put on BIOS reader
                                          by BMCappelletti
                                          Long story short:
                                          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                          - gave the computer to his son a couple years later
                                          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                          (seems like the story was not that short)
                                          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                          01-08-2025, 07:27 PM
                                        • Troystain
                                          Help EZP2023+ updated chip database for w25q256jveq?
                                          by Troystain
                                          Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                                          I need to add w25q256jveq chip but I do not know what data should I type.
                                          I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                                          The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                                          11-25-2024, 12:53 AM
                                        • inck243
                                          Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                                          by inck243
                                          Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                                          The BIOS...
                                          07-25-2024, 09:17 AM
