asus rog burn component, G703VI main board rev. 2.0
  • crozoki
    • Feb 2013
    • 44
    • Croatia
    Hello!
    Here is a motherboard from asus rog G703.
    G703VI main board rev. 2.0.
    On motherboard is burn one component and cannot read that component.
    The component is located on the opposite side of the laptop power button connector. I can turn on the laptop, but there is no picture and the fans are spinning at maximum speed
    can you help me figure out which component it is. thank you
  • mon2
    • Dec 2019
    • 14691
    Can read ‘D82’ on the top line.
    It may be the following:
    https://kasynparts.com/product/ps4-s...c-replacement/
    • crozoki
      • Feb 2013
      • 44
      • Croatia
      I have a donor board from a ps4 pro. it has this component on it.
      • mon2
        • Dec 2019
        • 14691
        Search for a similar looking part but with 'D82' SMD code on the component. The original component is apparently a load switch. The one on the shared pic is a part from TI and does not appear to be the same (may be a ADC / DAC).
        • Fobo
          • Feb 2022
          • 28
          • Sweden
          I can help you tomorrow if it hasn't been resolved for you yet! I have a motherboard lying around.
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • JDC
            (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
            by JDC
            ONN 100012588
            Issue: No Power, Then Rebooting After Main Board Change
            Short answer: replace main board and power board
            Technical answer: replace main board and Q306 & Q307 on power board.
            Long answer:
            TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
            07-15-2022, 07:39 AM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
