Help please..Lenovo ideapad 5 14itl05 power and charging problem
  • Dr.d
    • Mar 2024
    • 44
    Thanks for all the great information mon2! The board has been out for all my testing. I just plugged it in and tested....it now powers up on both sides of the usb c! I'm not sure yet if the other problem may be fixed as well. That being it operating and charging with both the battery connected and usb power adapter at the same time. I probably need to reassemble and test for that to see if its fixed too. But, its great to see this working now. So, what do you think I should do going forward? You think to risky to leave off and reassemble and send back to the customer. Or should I try and locate the replacement part? Maybe it's not even available. I haven't checked ebay or Digikey yet.
    • mon2
      • Dec 2019
      • 14214
      Good job! See attached. This ESD device is a SOT23-6 package.
      Here is a part that is suitable and will be a drop-in replacement for the above defective ESD suppressor:
      TPD4E001DBVR Texas Instruments | Circuit Protection | DigiKey
      While the board does not require the use of these parts, they are recommended. Transients from the 'outside world' of the logic board, are very common and can nuke this board again. Without such a component, the logic IC(s) will receive the spikes. Becomes much more expensive to repair if that should happen.
      • Dr.d
        • Mar 2024
        • 44
        Thanks so much mon2 ! You've been a Godsend, thanks for all the help. I'll let you know any updates and how it goes from here.
        • Dr.d
          • Mar 2024
          • 44
          Hello mon2....Hey, I just want to let you know that I did order the part from the link you sent me. Thank you! I got it in and installed it, Re assembled the laptop and tested it. Everything works now! Evidently that part was also causing issues with the battery and adapter. That being the adapter wasn't charging the battery either. Thanks again!!
          • mon2
            • Dec 2019
            • 14214
            Excellent work! Thanks for the updates. It is appreciated by all. One less unit for the landfill.
            • alterr333
              • May 2019
              • 43
              • México
              #26
              Originally posted by mon2
              Yes, see attached.
              Mon2 master by chance could yoou upload the brd for this machine???
              Got one yesterday, signs of humidity in PUZ1 resoldered, but no joy, machine negotiates 20v, but onle 5v alw on, 3v3 alw missing
              • mon2
                • Dec 2019
                • 14214
                If any power rail is missing -> remove all power -> meter in resistance mode -> measure the resistance to ground. Need to confirm that there is no low resistane on that rail which can cause an excessive current draw -> will power down the rail.
                So start with the 3v3 ALW rail and also confirm that the rail is being ENABLED. Measure the voltage to ground of the ENABLE pin for that rail.
                • alterr333
                  • May 2019
                  • 43
                  • México
                  #28
                  i managed to fix this laptop by resoldering MP2940AGRT , then machine started to act different, i had a 3amp current draw spike, wich led me to QQ ic, SY8386BRHC, PU301, using the thermal cam, saw where the spike came from, rising temp to 60 degrees instantly, so lucky enough had a few new ones QQ to swap, so i did, tested and machine is up and runing again. charges and its ready to go back home, thanks man, best regards from the mayan riviera
                  • mon2
                    • Dec 2019
                    • 14214
                    Great update. Thanks.
                    See attached for the ESD array @ DT8
                    DT8 = CESD2510UC3V3U
                    Datasheet:
                    2009171509_CREATEK-CESD2510UC3V3U_C575940.pdf (lcsc.com)
                    This is a very common footprint ESD protection device available from assorted vendors including Texas Instruments / SOCAY, etc.
                    laptop freezes, usb 2.0 not working, usb 3.0 working - Badcaps
                    * see my post # 10 for details on other parts that can replace this one
                    Click image for larger version  Name:	esd_diodes.png Views:	0 Size:	84.3 KB ID:	3338632
                    • nebbia88
                      • Apr 2009
                      • 8
                      #30
                      just chiming in to say I had a similar fault, no power at all from the charger. DT16 was shorted gnd to vdd , DT1 had no apparent issues but removing both was needed. ill order some new ones but in the mean time its back to life.
                      this was caused by a dead DELL charger. one "flash" on the charging led as soon as i plugged in and no more charging since.
                      somehow using a powerbank which only gave 20W at 12V allowed it to charge slowly? althought only when laptopt was OFF.
                      Its like it didnt need to communicate , really confusing stuff.
                      • mon2
                        • Dec 2019
                        • 14214
                        Thanks for your feedback. It is nasty how a simple low cost device can cause the logic board to fail. As noted, there are assorted crosses for this part from various manufacturers. You can probably source through Digikey / Mouser / Arrow, etc. in addition to Aliexpress.
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                        • claws77
                          lenovo flex 5 14itl05 power sequence issue
                          by claws77
                          hi guys, my motherboard will not start no matter what
                          when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                          but rest nothing happens no sign of life.
                          this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                          with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                          but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                          i have no knowledge of motherboards ....
                          10-20-2024, 02:48 PM
                        • rabsonnjala
                          LENOVO IDEAPAD 100 works only on bench power supply
                          by rabsonnjala
                          Hie I have a Lenovo laptop
                          Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                          it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                          below are my readings
                          with the original charger only
                          JBATT1
                          PIN1 0.22V
                          PIN2 0.22V
                          PIN3 0.45V
                          PIN4 0.45V
                          PIN5 O.43V
                          PIN6 0V
                          PIN7 GND
                          PIN8...
                          11-20-2021, 08:32 AM
