HP 13-ad017nc - doesn't start
This topic has been answered.
  • YellowJacket
    • Dec 2020
    • 105
    • Slovakia
    I got this laptop to fix, this is known history - firstly, laptop had some troubles with turning ON ( turned on at third attempt, or so ). Then, during windows installation, USBs were not working at all ( it was unable to detect any USB flash stick ). Even after installation and looking for some drivers. Then a guy told me, he tried to install some software ( from last conversation, it should be "any desk" software ), and during installation the laptop shuts down. From that moment, it doesn't turn on. After connecting the charger, there is no light on charging port ( as it should be I suppose ), but an LED on the power button is turned on permanently. Still no reaction when I press it. Battery connector is ripped off of the board, so I am working without battery ( will fix it in case, I repair the board ).
    What I discovered already:
    - 5V power rail had too small resistance; I found damaged IC --> TPS2546 along with a ferrite bead connecting the IC and the USB port. After removing them from the board, resistance of 5V power rail raised up to kohm range
    - I tried 3 different BIOS firmware, one found somewhere here on badcaps, and two repaired ones ( from discord, thank you guys, if you read this ). Laptop acts the same, with all firmware, even with removed EEPROM IC
    Since I have no schematic ( requested here, but no luck so far ), or board view, I have no idea, how does power sequence look like here. So I don't know, what to check. From my view, it looks like EC is not responding. Or I got hint, that one of the coil has too low resistance to ground, even if it has voltage ( the one with 1.4 ohm ), but again, I have no idea, what power rail it is. So maybe dead PCH too.
    I would be thankful, if anyone of you can help me, how to confirm dead EC/PCH, or just where to start. For now, I am not going to fix USB, because well, it has no sense in this state. Thank you in advance, and if you need any other info, let me know.
  • Answer selected by YellowJacket at 04-09-2024, 12:06 AM.
    YellowJacket
    • Dec 2020
    • 105
    • Slovakia
    Thank you, piernov. Actually, you hit the jackpot. Amazing deduction!
    I tried to hook a PSU on the LDO 3.3V output ( even, if there is kohm range ), and current consumption was around 300 mA. And no, it was no EC. There was two schottky diodes in its way, and behind second diode was like zero point something resistance to ground. Injection of 0.9V at that point heated up PCH in up-right corner of its crystal. So yeah, nice to meet you, donor board.
    I only wonder, if this was just random failure, or the customer did something ( he previously wanted me only to fix the USBs - messing with USBs can fry PCH ) and he caused it all. Anyway, thank you all guys for your support and patience, I wouldn't made a single step without your clues. Take care, see you next time.
    • mon2
      • Dec 2019
      • 14664
      Hi.
      1) apply the best bios available to you for this board.
      2) attach the power adapter. Locate the dcin connector and nearby will be the dcin mosfets. Post their top side markings or better if clear pics can be taken. The charger ic will also be nearby and will be a square black ic. Which charger ic is onboard?
      Do you see any LEDs turn on the board? Led blink sequence?
      What is the voltage to ground starting the dc adapter input connector? Meter in DC volts scale of 30v or more. Red probe on point to measure. Black probe to ground (metal shield is ok).
      • YellowJacket
        • Dec 2020
        • 105
        • Slovakia
        Hi mon2
        1.) I flashed there original bios dump, after cleaning its ME region. As I mentioned, the laptop behaves always the same though. If you think, it is bios related, let me know, I will ask here on badcaps for another dump
        2.) First DCIN mosfet is AON6428, second mosfet is AON7414. Charger IC is BQ738
        - about LEDs : the one on the charging port, it is all time turned off. Then, there are three LEDs under power button. These LEDs are meant to shine together I believe, and this power button lights all the time, from the moment I connect the charger. No other LEDs on the board
        - there is 19.9V on drain of both mosfets, same voltage for source of both mosfets. 25.66V on gate of both mosfets
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Dc-in fet biasing is correct. Absence of light on dc jack is almost a sure indication of missing 3V LDO rail. Locate your 3V regulator,check datasheet if available and check 3V LDO is present or not. If not present,check resistance to GND on 3V LDO.
          • YellowJacket
            • Dec 2020
            • 105
            • Slovakia
            Thank you mcplslg123 , you gave me really difficult task though.
            I tried to analyze the circuitry as much as I could, and I looked around both 5V coils and the 3.3V one. But all three had nearby an IC, which was hard to find datasheet of. First picture is an IC connected to 5V coil on the left ( from picture in first post, 3k5 resistance ). Second picture is an IC connected to 5V coil on the right ( 22R5 resistance ). Third picture is an IC connected to 3.3V coil ( 3k3 resistance ).
            Anyway, I was able to measure 3.3V on one capacitor nearby EC. On the another two nearby I was able to measure 2.9V. Sadly, EC has SMD package, so no way to figure out, where is 3.3V LDO going into it. So now, I am trying to find out some datasheet of these three ICs and get some info, if any of these have LDO regulator integrated. Feel free to lead me, if you have any other idea, what to check. I am really helpful for any of your hints, guys. Absence of schematic for this particular board makes it so tough to fix for me.
              • 21881
              The 1st chip is a Silergy,the other 2 are Monolithic Power .You`ll find all 3 marking codes in the IC Marking Codes sticky thread -> https://www.badcaps.net/forum/troubl...and-datasheets
              • YellowJacket
                • Dec 2020
                • 105
                • Slovakia
                SMDFlea thank you so much, that information was very important to me! I am sorry, that I didn't check that topic before, I somehow missed it.
                So update:
                - first picture is SY8284CRAC, but datasheet is probably still not available, there is only some schematic of its connection on google. Anyway, I was able to measure 5V at one of its pins ( capacitor directly connected on it ), which is not connected to 5V switching supply. So, considered it as working fine
                - second picture is NB679A, and it works correctly - both switching and LDO 5V voltage is up and running
                - third picture is NB680, and it works - switching voltage is 3.3V and LDO voltage is 3.0V. Moreover, output from LDO regulator 3.0V is directly connected to those two capacitors nearby EC, I mentioned before. So from this point, I suppose, LDO for 3.3V is up and running and EC has its power.
                • YellowJacket
                  • Dec 2020
                  • 105
                  • Slovakia
                  Looks like I am not alone, who is lost in this case without schematic. So to finish it somehow - do you guys at least have any idea, how to confirm dead EC ( corrupted EC firmware included ), eventually dead PCH, without schematic?
                  Also, is 1.4 ohm resistance to ground on that 1V power rail too low?
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Resistance to GND on 1V rail at 1.4 Ohms is considered too low indicating perhaps towards a shorted PCH. Without schematic & boardview, its impossible to troubeshoot a BGA EC.
                    Since, 3V LDO is present and still dc jack light is not glowing, it could be either bad main bios or corrupt ec firmware. Try flashing them both first preferably from HP official biosupdate file .
                    • piernov
                      • Jan 2016
                      • 4439
                      • France
                      LDO output should be 3.3V, if it is 3.0V it is maybe pulled low by a shorted component.
                      • YellowJacket
                        • Dec 2020
                        • 105
                        • Slovakia
                        • piernov
                          • Jan 2016
                          • 4439
                          • France
                          Yes, typical short on the RTC power rail sadly. Can happen randomly but yes something on USB can also damage the PCH.
                          • Nagy Daniel
                            Lowest possible resistance on laptop motherboard rail - Guide Table request
                            by Nagy Daniel
                            Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                            I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                            I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                            So, I generated a table with AI so I can...
                            03-04-2025, 08:24 AM
                          • motormayhem
                            Lenovo T460 Only Charges on One Charger
                            by motormayhem
                            Laptop Question
                            I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                            A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                            05-12-2023, 01:46 PM
                            NVDC charger configuration...
                            11-05-2024, 03:28 PM
                          • flat-earther
                            how to prevent a connected charger from draining battery when not charging?
                            by flat-earther
                            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                            So the battery is backfeeding the charger and being drained.
                            How can I prevent...
                            08-07-2025, 01:04 PM
                          • flat-earther
                            ASUS X54H laptop thinks it's always charging even with charger unplugged
                            by flat-earther
                            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                            Windows also shows ''Plugged in'' when charger is not connected.
                            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                            If I let battery run out and say it has 3% Windows will...
                            06-24-2025, 09:32 AM
