Logging keyboard/trackpad activities system utility
  • harp
    • Jun 2022
    • 642
    • Planet Earth
    have a hp probook 450 G1 laptop with win10 and have some problems with keyboard/tuchpad related to temperature, humidity or condensation.
    It behave that when poweron in cold room starts randomly glitches like a open/close search window tab, most time stay on screen opened and mouse cursor run totaly on left border, or be locked on place, occasionaly let me to pass movement to go. Movement is hard or partialy disabled, like he has already got (has filled with) command what to do... it is hard to describe.
    After a while, few minutes, everything is ok. I suspect a trackpad because of cursor fast movement over screen to left, and because it is disabled for functions till glitches gone, but dont know what is related with search popup... its like he is bring it up with some sort of shortcut or so... maybe keyboard?
    Every key is working as I can see...
    I want to inverstigate this before warm weather, the way I thing to go is to launch some system utility who monitor and log presed keyboard or mouse... is any preinstaled on win10?
    Any idea from similar experiance issues or other way to go?​
  • mitchw
    MacBook Pro M4 Pro - no keyboard / trackpad / lid sensor
    by mitchw
    Hello
    I got this MacBook Pro M4 Pro to have a look at.
    It was tiny bit liquid damaged, just the edge of the board got 1 small 10x10 mm area wet. I've seen much worse that still worked fine to be honest.
    Since it was liquid damaged, warranty does not apply anymore.
    Anyways it was checked at an local Apple Store and they discovered that it needs new trackpad, new top case, etc. Also it needed a new lid angle sensor which they replaced.
    The main issue was that the screen remained black.
    Anyways I cleaned the liquid damaged area, put the machine back...
    09-06-2025, 07:19 AM
  • No Lan
    [Macbook pro A1708] [Boot loop] [Trackpad ?]
    by No Lan
    Hey everyone,
    Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
    Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
    Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
    05-24-2025, 03:09 PM
  • guzq
    MBA13 M3 2024 A3113 EMC8611 820-03285 No Trackpad No Keyboard (water damaged)
    by guzq
    Hi Guys,
    This Mac come with dead issues (severe water damage), now it’s turning ON except Trackpad and Keyboard not working.
    Already check and write down DM for JT400 and JT201 don’t find any abnormal value (I don’t have unit for compare).
    Already try,
    • Replacing Trackpad Flex Cable
    • Replacing New Trackpad
    • Replacing Little Board (Daughter Board)
    • Try using New Keyboard
    Still no change at all, Trackpad and Keyboard not working.
    So I check “Power Load Switches” and this is all the numbers,
    UC830 > 1 = 3.297V ; 3 =1.757V ; 4 = 3.798V...
    07-08-2025, 05:19 AM
  • iMuhtaseb
    A2681 Keyboard, trackpad and sleep?!
    by iMuhtaseb
    Wow it's been a while since I posted!
    This is a weird case, it has a history of liquid spill a year ago but customer did not want to replace neither trackpad or keyboard.. fast forward for today:
    A2681 turns on but not trackpad or keyboard feedback (or external keyboard and mouse) and then after a minute or so the Mac sleeps..
    It's a NOT a sleep sensor or trackpad or keyboard or daughterboard or anything else (I replaced all those); it's the logic board..
    Tested another locked logic board on customer's top case and it posted with keyboard and...
    05-22-2025, 09:59 AM
  • nicocorradini
    820-00426 (A1398 2015) no trackpad, no keyboard.
    by nicocorradini
    Hi! I have this 2015 A1398 with 820-00426 board that's driving me crazy. It originally came because of charging problems (MagSafe Board roasted, also MagSafe cable, etc. After disassembly, clean and assembly, my assistant (literally) broke FL803 and other componentes. Obviously, no screen or backlight. After replacing them, and also the LVDS connector, and LVDS flex on the screen, the board started fine, charges, chimes, shows Apple Logo, but surprise: no more trackpad or keyboard.
    Important notes:
    -Click works, so, trackpad is alive.
    -Already tried with another trackpad,...
    03-04-2025, 07:01 PM
