Hiopos - Cash Touch - Doesn't turn on
  • samstown
    • Mar 2021
    • 122
    • Switzerland
    I have this Hiopos Cash system running on android that stopped working without notice. The power supply is ok, there's light on motherboard but when pressing power button it doesn't turn on.
    I've google for schematics but no luck. Motherboard is S2802_V1.3B. I've took some measure and maybe it could be a transistor, the one I am pointing on with the orange arrow on the pics. Does anyone knows this board ?
    Sam
  • mon2
    • Dec 2019
    • 14285
    Start with the main 12v power rail. Is it a stable 12 volts to ground?
    Next, suggest to review the Sipex RS232 transceiver which is on the bottom side of one of the posted pics. You can download a full datasheet for this component from Maxlinear (who purchased Sipex/Exar). From this transceiver, you can locate the Vcc rail. Given that all pins are @ 0 volts, the Vcc for this RS232 xcvr is lost so you are missing at least this power rail.
    Once you locate the Vcc power pin, remove all power (no pun) -> meter in resistance mode (not diode mode) -> measure the resistance to ground of this Vcc pin. Varying with the age of the design, this Vcc may have been the 5v0 rail or the 3v3 rail. These are charge-pump RS232 xcvrs which will then accept this rather low voltage and then perform a voltage multiplier to often 2x the Vcc rail to support RS232 voltage interfacing.
    Start with this review and then perhaps we can determine which power rail(s) are defective. At the very least, the 12 volts used as the input must be present and stable. The onboard xcvr is 16 pin SSOP so my earlier post had the incorrect pinout.
    See the correct one below. Remove all power -> meter in resistance mode -> measure the resistance to ground of the VCC pin. We know from your first post that this Vcc rail is at 0 volts. Is this due to a shorted cap or some other reason?
    • samstown
      • Mar 2021
      • 122
      • Switzerland
      Hello, thank you very much for your reply and your help.
      You are right, VCC is shorted to ground. Should I try to inject 1V on SP3232E Pin 16 and look for heat component with thermal camera ?
      • mon2
        • Dec 2019
        • 14285
        Can you share the exact resistance measurement? Confirm also that your meter is reporting the reading in ohms (not k; not M; not OL).
        If truly a low resistance than yes, it will most likely be one of the shorted / partially shorted caps but to be determined.
        Will be great to use your thermal camera if available or you will have to resort to pour IPA (alcohol; we use the Costco stuff). Which ever part evaporates the alcohol quickly, it is running hotter than room temperature. Caps are the first suspect but do inspect for possible cracked regulators, etc. Someone is tanking down this required power rail.
        1 volt injection is fair to use at the highest current your power supply can support.
        • samstown
          • Mar 2021
          • 122
          • Switzerland
          It looks like a short to ground.
          • mon2
            • Dec 2019
            • 14285
            The meter scale appears to be in diode mode so select another scale to confirm. If testing in diode mode, place the red probe to ground and the black probe onto pin #16 of this transceiver. Post your measurement.
            • samstown
              • Mar 2021
              • 122
              • Switzerland
              Thanks. If I set to 20K, I get 0,00
              • mon2
                • Dec 2019
                • 14285
                Yup, dead short. Hope it is only a bad cap (most likely). Proceed to apply a voltage for injection. Your (injection) DC power supply @ 1 volt should peak to the max current which in turn should cause the shorted part to heat up. If not enough, increase the current if possible and then the voltage (in this order). Often, the cap will split open and usually it is the tantalum capacitor. Curious on your updates.
                • samstown
                  • Mar 2021
                  • 122
                  • Switzerland
                  resistor in red was getting hot. I removed it but short was still there. I removed the litle cap, not the big one. short is gone, I measue 0.25 when set to 20K. Device doesn't turn on, still 0V on VCC on that spirex chip PIN 16
                  • mon2
                    • Dec 2019
                    • 14285
                    Place back the resistor that was getting hot. It is probably a ferrite bead that is in series with this Vcc rail. Then test again.
                    Update:
                    On the right side of the shared pic there are a few USB connectors. Review the voltage to ground for the pin with 5V label. This is used to power the USB connector VBUS pin.
                    • samstown
                      • Mar 2021
                      • 122
                      • Switzerland
                      Thank you for all your help. I had two of those. Following your instruction, I was able to fix the second one, the issue was on the Wifi module, the chipset was getting hot. I remove it and now it boots.
                      I will try to place back the resistor one the first one tomorrow morning.
                      Have nice end of day and thanks again.
                      • mon2
                        • Dec 2019
                        • 14285
                        Excellent. Good job!
                        • Nagy Daniel
                          Lowest possible resistance on laptop motherboard rail - Guide Table request
                          by Nagy Daniel
                          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                          So, I generated a table with AI so I can...
                          03-04-2025, 08:24 AM
                        • trepachka
                          Converting HP EliteBook 840 G7 non-touch to touch if possible
                          by trepachka
                          I am trying to convert a HP EliteBook 840 G7 notebook from a non-touch to a touchscreen. I purchased a complete touch LCD assembly with a screen/back cover/bezel/video cable and swapped it out with the original non-touch LCD assembly.
                          The screen works but the touch does not. I know the new LCD assembly is completely functional because we tried it on a similar touchscreen EliteBook 840 G7 and the touch works there.
                          I contacted the seller and he said screen conversion like this will not work due some difference in the motherboard for non-touch and touch capable EliteBook 840 G7.
                          04-27-2024, 11:15 PM
                        • Prott
                          Surface Pro 4/5 - no touch after LCD change
                          by Prott
                          I have a question that's driving me a bit nuts recently.
                          Is the touch board on Surface Pro 4/5 somehow married to the motherboard? I have a few Surfaces that, after the touch board change, lost all touch functionality.
                          - I tried flashing the bios (simple ME clean from a known good bios, previous bios didn't have an intergrated hub enabled), reinstalling firmware, reinstalling windows and even new touch boards.
                          - In one instance, after I tried to troubleshoot by using a known good screen + touch pcb combo on a Surface that lost touch, the touch board...
                          01-25-2023, 12:42 PM
                        • Victor Moreira Silva
                          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                          by Victor Moreira Silva
                          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                          Well, my decice specs are the following:
                          Model: Acer Nitro 5 AN517-54-55T5
                          CPU: Intel Core i5-11400H
                          GPU: NVIDIA GeForce GTX 1650
                          Motherboard: GH51G LA-L181P Rev:1c
                          The symptom:
                          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                          05-26-2025, 10:49 AM
                          Dynabook Portege X40-K, i7-1260P, 14" FHD TOUCH, 16GB, 512GB SSD, T/BOLT, W11P, 3YR Notebook Specification for Upgrade or Repair
                          This specification for the Dynabook Portege X40-K, i7-1260P, 14" FHD TOUCH, 16GB, 512GB SSD, T/BOLT, W11P, 3YR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X40-K, i7-1260P, 14" FHD TOUCH, 16GB, 512GB SSD, T/BOLT, W11P, 3YR boardview and X40-K, i7-1260P, 14" FHD TOUCH, 16GB, 512GB SSD, T/BOLT, W11P, 3YR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                          09-07-2024, 05:50 AM
