DAOR33MB6E0 REV:E Partial ON
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 347
    • India
    Hi This board turns on
    after starting consumes 0.09 Amps
    3.3 and 5 volts ok
    1.5 present at LP16
    1.7 Present at PL 15
    1.05 Present at PL 17
    .9 Present at PL23
    no other power reading
    Tried to bios flashing ,came to know U31 bios chip pin 7 is found open, Replaced chip/flashed , still same condition
    Thanks for Helping
    • 21451
    Post a LINK to the schematic..
    Reminder: rules and organization of this section - https://www.badcaps.net/forum/troubl...f-this-section
    • ravi_1617
      YY Solutions
      • Jan 2012
      • 347
      • India
      3.3 and 5 volts ok
      1.5 present at LP16
      .9 Present at PL23
      Thanks for Helping
      Sorry Admin .i did attached ,might be mistake from my side ,please Hepl me
      Link to schematic --->>> https://www.badcaps.net/forum/troubl...02#post1236002
      • ravi_1617
        YY Solutions
        • Jan 2012
        • 347
        • India
        Please help to proceed someone
        • mon2
          • Dec 2019
          • 14532
          Carefully measure the voltage to ground of each pin on the charger IC at PU9.
          Meter in DC volts scale of 30V or higher. Black probe be to ground. Red probe to point to test.
          Need to know (as a minimum):
          ACDRV
          ACDET
          REGN
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            What about PL30 voltage?
            PU13,pin15 voltage?
            PQ36/47/55-volatge on all pins?
            HWPG present?
            • ravi_1617
              YY Solutions
              • Jan 2012
              • 347
              • India
              [QUOTE=mon2;n3245146]Carefully measure the voltage to ground of each pin on the charger IC at PU9.
              ACDRV
              ACDET
              REGN
              These are the reading
              1 19.81
              2 19.81
              3 19.76
              4 24.98 ACDRV
              5 2.97 ACDET
              6 2.78
              7 4.6 mil volt
              8 3.32
              9 3.382
              10 3.34
              11 2.82
              12 2.81
              13 2.82
              14 GND
              15 000.3 goes to 0000
              16 5.93 REGN
              17 5.88
              19 2.81
              20 19.79
              At PL 16coil 1.5v also not present my mistake
              Thanks for your interest mon2
              • ravi_1617
                YY Solutions
                • Jan 2012
                • 347
                • India
                PU13,pin15 voltage?
                HWPG present?
                Sorry to say mcplslg123 unable to find Pl 30
                PU 13 Pin15 3.021
                didn't find PQ 36 &PQ 47
                PQ55 PIN123 3.3V
                PIN4 12.11v
                PIN 5678 3.392v
                Pleas help
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  There is boardview posted in this forum.use it to locate components and report back with the findings.
                  No help can be extended unless you answer in full. Hopefully, problem should be solved with united effort if not alone.
                  • ravi_1617
                    YY Solutions
                    • Jan 2012
                    • 347
                    • India
                    Thanks for your interest,
                    found Board view
                    PL 30 COIL is blank no power at both poins
                    PQ36 pin 1,2,5&6 3.391
                    pin3 12.12
                    pin 4 3.391
                    PQ47 PIN1,2,3 5V
                    PIN 4 12V
                    PIN 4-8 5
                    HWPG not present.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Share resistance to GND on coil PL16/PL30
                      Mainon present?
                      Voltage on pin10/11/12/13/15 of PU5 after pressing power button?
                      PU13,pin15 voltage?
                      • ravi_1617
                        YY Solutions
                        • Jan 2012
                        • 347
                        • India
                        Mainon present?
                        PU13,pin15 voltage?
                        Sharing update
                        PL16354 Ohm
                        PL3017.2 Ohm
                        Yes Main on Present
                        PU5
                        PIN10 3.321
                        11 3.349
                        13 9.2 mil vol
                        15 5 v
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          You forgot to mention pin12,PU5 voltage. PU5 seems powered and getting the enables as well.So Timer ON(TON) pin very important for it to give output.Check PR34 is 600K-often this resistor go bad. If PR34 is ok,replace PU5.
                          You've not shared PU13,pin15 ststaus aslo.
                          • ravi_1617
                            YY Solutions
                            • Jan 2012
                            • 347
                            • India
                            pu5 pin 12 15.40 showing
                            PR34 is ok .
                            i don't have pu5 spare . i will update you soon .
                            • ravi_1617
                              YY Solutions
                              • Jan 2012
                              • 347
                              • India
                              Just an update, Thanks after replacing PU5 ,board started/ fan spinning .,
                              than noticed bench power amps showing more than 2.5 amps. it was due to 1 of the Ram was short,.
                              now board starting , consumes around 0.60 to 0 70 , with no display
                              again flashed few bios, tried few Ram ,CPU also, same situation . no display.
                              when connected keypad found CAPS LOCK blinking every 4 Seconds continually .
                              https://www.badcaps.net/forum/troubl...mlock-flashing
                              the above post says to replace Intel . I have observed in my board . has AMD/ATI graphic chip and Intel also.
                              ATI not heating at all. but Intel is heating bit more even it has heat sink
                              do i need to replace Intel or something else to try
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                First convert this board to UMA. Its very simple and detailed info is there on internet.
                                • ravi_1617
                                  YY Solutions
                                  • Jan 2012
                                  • 347
                                  • India
                                  A small doubt .
                                  moving R550 to R549
                                  and removing PL27 coil,
                                  is that enough .to turn off VGA CORE power .
                                  not required to remove PU12,, PL12, or any thing else
                                  • ravi_1617
                                    YY Solutions
                                    • Jan 2012
                                    • 347
                                    • India
                                    A small doubt .
                                    moving R550 to R549
                                    Update removed PL27 COIL, moved R550 to R549,still board has no display. Intel PCH still heating ,
                                    I left it on for some time , after some time board turning off itself,
                                    tried many times same situation, Amp reading same around 0.70
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      Are you getting any voltage on PL29? Dramsrst# on ram slot pin30 present?
                                      Consumption on dc supply
                                      01.With ram stick
                                      02.Without ram stick?
                                      • ravi_1617
                                        YY Solutions
                                        • Jan 2012
                                        • 347
                                        • India
                                        01.With ram stick
                                        No voltage on PL29
                                        DRAMSRT# I measuring 1.615v
                                        Regarding your point 1&2
                                        As told before power Amps reading starts at .62 ........ slowly goes to .91 Amp and shuts down
                                        takes around 1 and half minutes
                                        • valente222
                                          HP 14 LA-A993P REV 1.0, identify ic? and not susp# present
                                          by valente222
                                          I have a Mb LA-A993P REV 1.0 computer, I am guiding myself with these two shared boards. ;
                                          there are some ICs that are not the same, in this case those of the PU1501 (JD4TB) and PUH1 (NF4SA) images.
                                          n, please identify.
                                          330mA of consumption after 8 seconds turns off. +3VALW AND +5VALW present, EC_RSMRST# , LID_SW# , EC_ON# , ACIN# present.
                                          SUSP# NOT PRESENT, which would be this the problem does not turn on sub-sources Any leakage?
                                          I also notice that in the PLH2 coil that belongs to +1.05VS according to the drawings I am not sure,
                                          06-27-2024, 06:11 PM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • air_chair256
                                          Lenovo Yoga 9I 15IMH5, MB LC40CM Won't Turn On, 1V_VCCGT is not present
                                          by air_chair256
                                          I have a Lenovo MB LC40CM 19863-1 when press button is pushed the keyboard backlight turns on and off twice and the power button light keeps blinking and the fans spins for a few seconds and stops then again spins and stops (Three times) then laptop turns off. no image on screen. sometime when you leave it for few days it will turn on and work but once you restart it won't turn on.
                                          Tried to reball RAM 1,2,3,4
                                          Checked all voltages on big coils all present except 1V_VCCGT is not present I get 0V on this rail. is this voltage should be present once power button...
                                          02-13-2024, 06:00 AM
                                        • javieromex
                                          Dell G15 5511 LA-K452P won't turn on
                                          by javieromex
                                          Hello, any help will be apprecited!
                                          • Model: Dell G15 5511
                                          • MB: LA-K452P
                                          • Issue: Won't turn on at all, no leds, no keyboard light, no fan spin, nothing happens when pressing power button. NOTHING.
                                          • Customer reported it was turned off and left plugged in during the night and thats it...
                                          • No signs of liquid damage or burned components.
                                          Link to Schematics -> https://www.badcaps.net/forum/troubl...la-k452p-gdp50
                                          I have checked so far:
                                          04-17-2025, 12:44 PM
                                        • Prott
                                          Surface Pro 7 - SLP_S4 present, then gone
                                          by Prott
                                          Hello fellow Badcappers,
                                          I have a problem with stubborn Surface Pro 7. I narowed it down to disappearing SLP_S4# (gone after around 200 ms).
                                          Everything else works as it should (the whole power on sequence succesfully finishes, all the voltages are present) until this signal goes missing - with it missing the AND gate causes ALL_SYS_PWRGD to go back low and this makes VCCIN drop to 0 V as well. Interestingly the SLP_S4_DRV# signal from SAM is still present for a second, even after SLP_S4 is no longer there. I wonder what could either cause PCH to stop sending the signal or what...
                                          12-03-2023, 06:11 PM
