Lenovo ThinkPad X250 strange power issue
  • sarry86
    • Jun 2021
    • 90
    • Tanzania
    Hello, I have this laptop ThinkPad X250 that has this strange problem, when connected to the main power source, the fan spin once, keyboard lit up for like 2 secs then turns off, only power button remain with solid green light and the ThinkPad icon at the rear lit solid as well, I have tried everything, wiping, writing bioses that users here requested and were given as working for the exactly the specific model but nothing works, the strangest thing is that, even if I completely wipe the bios and blank check it to make sure it is wiped, the laptop still start as mentioned above, have anyone ever met with this strange phenomenon? 🤔 I wonder how Lenovo bios system works, if anyone know please enlighten me 🙏
  • sarry86
    • Jun 2021
    • 90
    • Tanzania
    Could it be the problem with MEC1633L? 🤔
    • mon2
      • Dec 2019
      • 14677
      Could be assorted issues. Do you still have the original known good bios? It should be used for starters.
      Review the voltage to ground on each pin of the charger IC. Post the full list of measurements. Proceed with care so that the charger IC is not damaged from shorting of the meter probes across nearby parts or pins.
      • sarry86
        • Jun 2021
        • 90
        • Tanzania
        No I don't, just the one I backed up after the problem
        GND to :-
        EXTPWR = 0V
        LPMOD = 3.3V
        ACDET = 2.48V
        IOUT = 0.02V
        SDA = 3.3V
        SCL = 3.3V
        ILIM = 1.5V
        BM = 3.3
        CSN = 1.47V
        CSP = 1.47V
        BTST = 5.90V
        REGN = 6.00V
        SW = 1.46V
        LPREF = 0.5V
        PVCC = 1.49V
        • mon2
          • Dec 2019
          • 14677
          1) cute kid
          2) remove all power. Meter in resistance mode (not diode mode).
          3) measure the resistance to ground of pvcc power rail. Post the measurement.
          • sarry86
            • Jun 2021
            • 90
            • Tanzania
            1) cute kid
            1. Thank you so much ☺
            2. Reads 0ohms Click image for larger version
            • mon2
              • Dec 2019
              • 14677
              The posted meter pic is helpful. This measurement is not 0 ohms since meter is reporting OL (‘over limit’). This means the selected meter scale is too low. Switch to a higher meter resistance scale till you have a proper measurement. We know that the resistance of this rail is higher than 200 ohms. Post the true resistance of this rail.
              • sarry86
                • Jun 2021
                • 90
                • Tanzania
                The posted meter pic is helpful. This measurement is not 0 ohms since meter is reporting OL (‘over limit'). This means the selected meter scale is too low. Switch to a higher meter resistance scale till you have a proper measurement. We know that the resistance of this rail is higher than 200 ohms. Post the true resistance of this rail.
                Here
                Both in MegaOhms and KiloOhms range, I don't understand, why is it showing two different readings? And why are the caps charging in resistance mode? 😳
                Click image for larger version  Name:	IMG_20240325_122537.jpg Views:	0 Size:	4.32 MB ID:	3241862
                Click image for larger version  Name:	PXL_20240325_114628212.jpg Views:	0 Size:	3.09 MB ID:	3241804
                • sarry86
                  • Jun 2021
                  • 90
                  • Tanzania
                  Please help me, is that resistance what is supposed to be?
                  • mon2
                    • Dec 2019
                    • 14677
                    The new shared resistance values are ok. They confirm there is no short on the tested rail.
                    Remove all power. Meter in resistance mode (not diode). Measure the resistance to ground of each inductor (usually will be grey in colour with 2 leads).
                    hunting for low resistance rails. Post the measurements.
                    • sarry86
                      • Jun 2021
                      • 90
                      • Tanzania
                      Sorry for the late reply, here
Name:	CamScanner 03-28-2024 11.00~2.jpg
                      • mon2
                        • Dec 2019
                        • 14677
                        The measurements look ok. The coils with the lower resistance reading are to be expected as these are coils used for a low voltage rail.
                        There are 2 independent bioses at work on the logic board. The main bios which you are working with and is read by the host CPU (intel / AMD CPU). Then there is the EC / keyboard controller IC which contains an internal 8051 microcontroller. Respectively, this EC IC has a local bios (sometimes this bios is internal to the package of the IC) which is responsible to provide for simple tasks like keypress decoding. The keyboard is a grid of connections (horizontal / vertical lines) to save on the total # of connections. When you press a key, the 8051 processor will decode where the horizontal and vertical lines shorted to decode the key being pressed. Being a mechanical action, there will be 'electrical bounce' so the 8051 will clean up this 'dirty bouncing signal' to offer a clean logic '1' or logic '0' for the keypress and release action. Otherwise, you may see multiple and random # of keys when pressing only a single time on the keyboard. This same 8051 is also used to monitor your power on/off button so the main bios could be blank and these sideband signals and triggers will still function due to the 8051 controller.
                        • sarry86
                          • Jun 2021
                          • 90
                          • Tanzania
                          So, this can be seen on the MEC1633L, is there an easy way to reprogram this chip by j-tagging it and use "any" programmer? 😳
                          Click image for larger version  Name:	Screenshot_2024-03-29-10-11-13-317_com.foobnix.pro.pdf.reader.jpg Views:	0 Size:	690.9 KB ID:	3244099
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                          • Mita99
                            Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                            by Mita99
                            Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                            Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                            Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                            04-27-2025, 07:20 PM
                          • claws77
                            lenovo flex 5 14itl05 power sequence issue
                            by claws77
                            hi guys, my motherboard will not start no matter what
                            when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                            but rest nothing happens no sign of life.
                            this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                            with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                            but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                            i have no knowledge of motherboards ....
                            10-20-2024, 02:48 PM
                          • coasterghost
                            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                            by coasterghost
                            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                            System Hardware:
                            Processor: AMD Ryzen 7 PRO 5850U
                            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                            09-08-2025, 10:46 PM
                          • Maxpower3
                            Brand name and Model Type for Lenovo error 2202 product name is invalid
                            by Maxpower3
                            Info for error 2202 LenovoThinkPad models and type
                            Extract from ThinkPad Maintenance Utilities Configuration File
                            plnsrv.ini Version 1.01
                            Some information that may be useful
                            There must also be missing models, add them to the list if you know of any.
                            Code:
                            brand name
                            20B1=ThinkPad Edge E445
                            20B2=ThinkPad Edge E545
                            20BC=ThinkPad Edge E145
                            20BM=ThinkPad X140e
                            20BL=ThinkPad X140e
                            20A3=ThinkPad X230s
                            20AH=ThinkPad X230s
                            20AK=ThinkPad X240s
                            20AJ=ThinkPad X240s
                            02-21-2024, 10:27 AM
