Donor IC question?
  • roxboy1984
    • Jan 2022
    • 177
    • South Africa
    Donor IC question?
    Hi Guys, I have a Dell XPS 13” laptop that I’m trying to repair. If I look at the board with a thermal cam. The following component “3W=Q2W” which looks like a voltage regulator is getting very hot. So my question is. Can I swop it out with this one. “K2L31”? I can’t seem to find any data sheets. Please see pics for reference. Thanks for any help or advice.
  • mon2
    • Dec 2019
    • 14108
    No, not till there is 100% confirmation that they are the same form, fit and function. So far, only know that they are the same sot23-5 package.
    Which exact Dell model are you reviewing?
    '3W=' = Richtek.
    • roxboy1984
      • Jan 2022
      • 177
      • South Africa
      '3W=' = Richtek.
      Thanks so much as always for your help. The two models that I have are attached. The one that I’m trying to repair is the 9360.
      • mon2
        • Dec 2019
        • 14108
        See attached. Part reference is PU202.
        Part # RT9069-33GB
        https://www.digikey.ca/en/products/d...9-33GB/5270908
        You should be able to source replacements from other vendors. Is a simple 3v3 LDO. Confirm the pinout and max current support against the original by Richtek.
        Click image for larger version  Name:	PU202_Richtek.png Views:	0 Size:	125.9 KB ID:	3230977
        Click image for larger version  Name:	PU202_bv.png Views:	0 Size:	106.8 KB ID:	3230979
        Click image for larger version  Name:	pu202_bv2.png Views:	0 Size:	36.2 KB ID:	3230980
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          First you should remove the part and measure resistance to GND on output pin before proceeding for replacement.
          • roxboy1984
            • Jan 2022
            • 177
            • South Africa
            Part # RT9069-33GB
            Do you by chance know the Vendor of the "K2L31" ? or possibly have a boardview for the LA-H931P?
            • mon2
              • Dec 2019
              • 14108
              Hi. No, the 2 parts are not the same.
              The original component on the board is a 3v3 LDO which is capable of accepting a rather high voltage as the input and output the 3v3 voltage rail.
              The component you have with the 'K2' prefix is a USB load switch which acts like a solid state relay. The reference datasheet for the 'K2' component is available here:
              https://datasheet.lcsc.com/lcsc/2111...0_C2919834.pdf
              BV for XPS9360? Yes, have it but is marked as 'LA-D841P'. It was used to identify the PU202 component. Will post it in the schematic forum once at the office if still of interest. The LA-D841P BV file may already be available in the schematic forum.
              • David Stroe
                AOC CQ27G2U/BK - in need of data sheets
                by David Stroe
                I am trying to repair my monitor that shows image but the backlight is not turning on. I think either the power supply is not working properly or the LED strip is failing, which seems unlikely (the whole strip is off).
                I really need help in finding the data sheets for this monitor's boards. The data sheets I need are for the following boards:
                Power Supply: 715GA907-P03-000-001S and 715GA721-P01-000-0H4K
                Main Board: 715G9500-M0C-B00-005K
                T-CON Board: 19Y_270_EU3MQ_SR_V02_HF
                If someone could please provide any of these data sheets, it would be awesome....
                05-31-2025, 11:12 AM
              • speaktorob
                Reference Nvidia GTX 980 ti - looking for a new shroud
                by speaktorob
                So a while back, to deal with the fan noise of the old blower style shrouds on the reference cards, I chucked it and installed the monster that is a Raijintek MORPHEUS 8069, with a couple Noctuas on it. Did the job but quite unwieldy tbh.
                Anyone know which boards would have a compatible shroud for it? I know the EVGA used the reference board but wondering if any other manufacturers did. I want to put something sensible back on it, but I'm having a hard time getting hold of even a faulty reference board for a reasonable price.
                03-22-2024, 03:00 AM
              • Raulnn
                clean hisense inner sheets
                by Raulnn
                Can you clean the internal sheets of a tv? I have a 58-inch TV and I don't know if it's worth cleaning the sheets. I have seen that it has dirt on the sheets and the leds are blown. I don't know if they look good when you clean the sheets. Thanks in advance.
                01-22-2023, 05:19 PM
              • Rhork
                Chip reference DA0G7BMB6D0 rév D HP Pavilion - 15-cs0006nf
                by Rhork
                I would like to know the reference of a QFN-20 because the reference marked on the chip does not give anything...
                PC Reference : HP Pavilion - 15-cs0006nf
                Motherboard : DA0G7BMB6D0 rev D
                Reference marked on the chip: AWVAIL
                Type : QFN-20
                I didn't find a boardview or repair schematics
                Thanks in advance...
                03-30-2022, 11:32 AM
              • Rickkap
                A2338 820-02020 Wifi Swop
                by Rickkap
                I'm reaching out to see if anyone has done a Wifi UL000 swop from the same donnor board on an M1 A2338 Macbook Pro or if it is possible to do.
                If it is possible what needs to be replaced as i cannot find the rom chips to go with it as mentioned on this page:
                https://logi.wiki/index.php/T2_MacBo...IC_Replacement
                07-03-2025, 06:40 AM
