Clevo PC70DP issues
  • Rudolfl
    • Dec 2020
    • 19
    Clevo PC70DP issues
    Hi all
    I have one of those machines. Clevo PC70DP.
    Machine starts, but turns off quite quick. Just before turning off one can hear fans are spinning at high speed. Can be turned back on again right away.
    So, feels like overheat problem.
    I cleaned up fans and heatsinks and replaced thermal paste. I can now see CPU runs cooler and machine stays on for longer, but still same.
    Few more findings:
    1. on-board NVIDIA card is not found. Not showing up in Windows or in BIOS.
    2. I tried to run CPU stress test. CPU stays at about 65 degrees. Works OK
    3. Looked at the board with thermal camera. "hotspots" are CPU, multi IO chip and M2 drive.
    Machine works OK, running just one fan on CPU side. Then it would suddenly (just idling in Windows) turn on both fans on high speed and turn itself off a minute later. At this time, thermal camera is not showing any changes in temperature of the components and no new "hotspots".
    To me it feels like a "runaway" temperature sensor telling CPU it is overheating and machine turns itself off. The fact NVIDIA chip is not detected makes me think it is probably a GPU sensor.
    I think, NVIDIA problem is a primary source of issues, sou would appreciate any advice.
  • x_orange90_x
    Seven Leagues Slot Machine stop button issues
    by x_orange90_x
    I don't know if anyone here has experience with Japanese slot (pachislo) machines, but I sure hope so. I bought this machine last week in semi-working order. It would play and the reels would spin, but the stop buttons would not stop them at all. I found that the high-frequency filtering tantalum capacitor was bad on the reel stop board, along with the fuse being blown. I replaced the fuse and removed the capacitor. I haven't replaced the cap yet because I didn't have one on hand, but it's not necessary for the operation of the machine.
    The issue now is the Stop buttons are intermittently...
    02-12-2025, 10:01 AM
  • Fam787
    HELP! A1398 Dead,
    by Fam787
    I bought a second hand Mid 2014 A1398 MacBook Pro when I lived in Australia. I'd bought it as a back-up machine because I had a Mid 2014 MacBook Pro, and realising it might one day fail, I wanted a backup machine because I don't like change.
    Two weeks after buying MBP2, the seller called me to check if everything was OK with the unit, which I thought was odd. At that stage I might have turned it on a couple of times, but I'd not used it when he'd called. Over the last few years I used the machine seldomly because my original mac has been pretty OK. Every 3-6 months I'd charge it...
    12-27-2024, 05:19 PM
  • emil_t
    RTX3090 working fine but fans not spinning
    by emil_t
    Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
    04-12-2024, 06:54 AM
  • huzo
    CLEVO N970TF turns fans to the full and goes of
    by huzo
    The laptop is CLEVO N970TF with i5-9400, RTX2070, i haven't disassembled it yet to know what is the board number, i will update that later, but the issue is laptop turns on normally and works for about 2 minutes,then both fans turn on to the max and in 30 seconds laptop shuts down! Nothing is warm or even close to overheating...
    i manage to get linux up and running and monitor the temperatures from all sensors, and the peak one is 51 celsius from a cpu cores...
    So something is acting up and thinks the laptop is overheating? How to foul the board into thinking everything...
    03-06-2024, 05:28 AM
    ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
    This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
    09-12-2024, 03:28 PM
