Lenovo Z580 led flashing then off
  • robrock1
    • Jul 2013
    • 129
    • Ghana
    Hello i got this lenovo z580 when you press the power button led`s are flashing then imidiatly off, you can press the power button again it always flashes then off. What i've tried so far:
    flash EC & Bios
    Reflow chipset
    Remove Network IC and Sound IC
  • khaahk
    • Dec 2013
    • 743
    • Estonia
    Re: Lenovo Z580 led flashing then off
    Some secondary power rail shorted? Tried to measure gpu, cpu, pch rail resistance?
    Is there enough time to measure secondary voltages to see which ones come up?
    Another cpu? Without memory?
    • robrock1
      • Jul 2013
      • 129
      • Ghana
      tried everything already also no short voltages are there, i think its the chipset that is faulty.
      • kisk
        Computer Tech
        • Jan 2014
        • 78
        It does sound like GPU failure. Try a more aggressive reflow or reball (preferable).
        • mohamed.mostafa
          • Sep 2012
          • 40
          • egypt
          i need bios dump of z580 , please upload robrock1
          • alihomee
            • Dec 2012
            • 1565
            • malaysia
            so did u slove it .i also have same problem with same model when i run it without ram it works and does not goes off but if pluged memory it turns off imidiatly
            • alihomee
              • Dec 2012
              • 1565
              • malaysia
              i need bios files please
              • alihomee
                • Dec 2012
                • 1565
                • malaysia
                anybody
                • mohamed.mostafa
                  • Sep 2012
                  • 40
                  • egypt
                  here bios dump
                  • computersss
                    • Oct 2014
                    • india
                    thanks boss
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3553
                      • slovakia
                      u must have some short maybe a capacitor in memory power rail
                      • ghojariya abdul
                        • Jul 2014
                        • 39
                        • india
                        in my case i found one brown capasitor near right click button was leaky, t shows 4 resitons on buzzer mode.of multi meetar.
                        • ciki
                          • Aug 2014
                          • 132
                          • Ireland
                          Have same problem did u fix??
                          • Grof_mo
                            • Feb 2015
                            • 5
                            • Bosna i Hercegovina
                            whether this bios responsible for ideapad Z585?
                            • memoslar
                              • Apr 2015
                              • 122
                              • Greece
                              Finally what was the problem, i have the same issue..
                              • ciki
                                • Aug 2014
                                • 132
                                • Ireland
                                Had same problem reflash bios or change ,there 2 bios chip i had case that one is ok second is bad after replacing them laptop works fine
                                • memoslar
                                  • Apr 2015
                                  • 122
                                  • Greece
                                  The problem solved! Thank you very much. I changed also both 2 bios chip. THANK YOU !!
                                  • ktmmotocross
                                    Boardkiller
                                    • Feb 2014
                                    • 3553
                                    • slovakia
                                    did u try to look after bios communication?
                                    • Ashwani jangir
                                      • May 2015
                                      • 5
                                      • india
                                      plz help me ...i need a bios lenovo z480
                                      • ovyyman
                                        • Jul 2015
                                        • 44
                                        • romania
                                        i was the same problem with led flashing an then turn of , i fix wit bios flash an than work fine , and than i pull out power cord whit batery inside and the laptop turn off automatical , now i hawe short circuit on main rail , i verify many capacitors withouth find the short circuit , i hawe short circuit on sideback of gpu motherboard maybe the cip is shortcircuited but i"m not shure , anybody knows any schematic diagram for this model , thanks
                                        • B2L_Repairs
                                          Lenovo g50-80 charging led flashing but laptop not switching on
                                          by B2L_Repairs
                                          I got a lenovo g50-80 that shows charging led (orange LED flashing) and when I press the power button the white LED comes on but the laptop doesn't switch on. The fan spins for 2 seconds when I press the power button then it stops. This problem started when my charging dock broke the connecting wires and i soldered these wires back but I might have mixed them. I ended up buying a new charging dock but laptop never switched on it just shows flashing orange LED when charger is connected. Could the super io be bad? I don't know how to go about diagnosing and I can't check any board view since this...
                                          01-19-2025, 12:28 PM
                                        • vickey_vip
                                          by vickey_vip
                                          I have same Problem And Solved by programming both bios at once
                                          i am posting tested bios maybe it help someone....
                                          08-15-2022, 11:34 PM
                                        • STKR123
                                          Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                          by STKR123
                                          As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                          I wonder if re-flashing the BIOS might be of any use here.
                                          As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                          There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                          11-03-2024, 06:58 AM
                                          Lenovo 3000 Series Schematic
                                          Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                          3000 C100 laptop with Braille keyboard
                                          Lenovo 3000 C
                                          C100, C200 - 15-inch XGA screen
                                          Lenovo 3000 N
                                          N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                          N500 - 15.4 inch screen.
                                          Lenovo 3000 V
                                          V100, V200 - 12.1-inch WXGA models
                                          Lenovo 3000 G
                                          G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                          10-04-2024, 06:05 AM
                                          Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                          09-06-2024, 06:40 AM
