Re: Lenovo Z580 led flashing then off
			by coasterghostFor Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
 Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
 Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
 System Hardware:
 Processor: AMD Ryzen 7 PRO 5850U
 Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...09-08-2025, 10:46 PM
			by JDongThere was an error... Aborting......I'm using another Linux Laptop with Zorin OS...to try and patch my Lenovo V15 G4 IRU with above specs....It originally had Windows 10/11 installed and converted to a dual boot Kali OS/Parrot OS system. I may have used the wrong lenovo_autopatcher_0.2 (I believe was posted by @knucklegrumble....I am out of ideas and flat broke so i cannot afford another fix (spent it all as an e-com entrepreneur does) any help from anyone would be GREATLY appreciated.....- Laptop Model: Lenovo V15 G4 IRU
- Issue: Forgotten supervisor password.
- BIOS Chip: GD25B128E (or GD25B128B
							Channel: BIOS Requests ONLY!
			by B2L_RepairsI got a lenovo g50-80 that shows charging led (orange LED flashing) and when I press the power button the white LED comes on but the laptop doesn't switch on. The fan spins for 2 seconds when I press the power button then it stops. This problem started when my charging dock broke the connecting wires and i soldered these wires back but I might have mixed them. I ended up buying a new charging dock but laptop never switched on it just shows flashing orange LED when charger is connected. Could the super io be bad? I don't know how to go about diagnosing and I can't check any board view since this...
			by STKR123As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
 I wonder if re-flashing the BIOS might be of any use here.
 As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
 There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
			Lenovo 3000 Series Schematic
 Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
 3000 C100 laptop with Braille keyboard
 Lenovo 3000 C
 C100, C200 - 15-inch XGA screen
 Lenovo 3000 N
 N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
 N500 - 15.4 inch screen.
 Lenovo 3000 V
 V100, V200 - 12.1-inch WXGA models
 Lenovo 3000 G
 G400, G410, G430, G450, G455, G510, G530, G550, and G560...-
							Channel: Schematics and Boardviews
 10-04-2024, 06:05 AM
- Loading...
