A1706
  • lucasbrand
    Lucas
    • 9
    A1706
    Hey folks,
    as, even after 24h after my introduction post, I am still not free to create a Thread, I tried to find the most suitable:
    I have this dead A1706. Here is what I have checked so far:
    • Ampmeter in all 4 USB C Ports: All same, 5.02V, 0.0A, no bootloop
    • (Not removing the Power Supply)
    • PPBUS_G3H at F7000: 17mV both sides
    • PP3V3_G3H at L6900: 0.4mV both sides
    • Check for enable at U6903 Pin 10 Test points: 0.31V
    I recreated those steps from a video. Now my question: The Voltage for the enable seems pretty low, doesn't it? What's next to check / to suspect to be faulty?
    Hope somebody is willing to take me by their hand . Thanks!
  • mon2
    • Dec 2019
    • 14677
    remove all power. Check the resistance on each side of F7000.
    • lucasbrand
      Lucas
      • 9
      Both sides same behaviour. Started with around 0.7 Ohms counting up continuously.
      • lucasbrand
        Lucas
        • 9
        Forgot to quote you
        • mon2
          • Dec 2019
          • 14677
          Flux and carefully remove F7000 off the board with hot air. We need to determine which side of the fuse is with the short. Most likely it will be the downstream (consumer) side rather than the upstream (producer / ISL) side.
          • lucasbrand
            Lucas
            • 9
            Ok, thank you! This will take some time as I will have to order tools.
            • lucasbrand
              Lucas
              • 9
              so what should I do then when the F7000 has been successfully removed?
              • lucasbrand
                Lucas
                • 9
                And as I struggle to find a beginners guide for desoldering chips, what is a good temp for the hot air station to use? Using severals values (slowly increasing) up to 350°C with some flux on the chip didn't get me to remove it with my tweezers...
                • mon2
                  • Dec 2019
                  • 14677
                  Really depends on your hot air tool + air pressure used. Most of these target PCBs are 8L or even more so there are solid copper planes that act like heatsinks. For this reason, an underside pre-heater helps but not always required. Suggest highly to practice on donor boards to learn the process.
                  Apply lots of flux -> heat at 350-400C for us works well (sometimes need to be higher but watch that you are not burning the board) -> go in tight circles to cover the entire device -> gently nudge (never rush or push too hard) on the device's corner to move when the solder is shiny and melted. Have ventilation to draw the fumes. Watch assorted videos on the same on YT.
                  • reformatt
                    • Feb 2020
                    • 1511
                    So just to confirm, is 0.7 ohms across the fuse, or a resistance measurement to ground for PPBUS_G3H?
                    • lucasbrand
                      Lucas
                      • 9
                      The measurement was to ground
                      • reformatt
                        • Feb 2020
                        • 1511
                        Ok, so on these boards with a dead short on PPBUS, I go straight to the CPU coils (L7210/L7220, L7270 etc) and check resistance to ground before anything else. If any are 0, then you have a DRMOS short and a dead CPU.
                        • obelix24
                          Macbook Pro 13" A1706
                          by obelix24
                          I have one strange issue with Macbook Pro 13" A1706 (touch bar) 4 TB ports
                          Issue is that all 4 ports are working but on one port only one side (when i rotate connector 180 degree there is nothing (ampmeter is not turned on at all) and charger (original apple) is put to protective mode, I have to unplug USB from the power brick to enable it again.
                          I've tried multiple USB-C ports (one one side all ports all sides work when i reconnect it to other side both ports work but one only on one side)
                          There is no issue problem on the board (no liquid damage, no damaged...
                          05-02-2024, 04:28 AM
                        • BC_TechForum_drb
                          Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
                          by BC_TechForum_drb
                          Sub: Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
                          Ref: 1/ MacPro6,1 Late 2013/A1481 MD878LL/A (3.5 GHz 6 Core Xeon E5-1650v2)
                          Gfx-B: APN: 661-7548 PPN: 820-3533-A AMD FirePro D500-B 3GB Vmem
                          2/ Figure 1 Gfx-D500-B Front Facing
                          3/ Figure 2 +5v supply (zoom-in)
                          Intro:
                          While troubleshooting a Mac Pro(6,1) referenced above I discovered the +5v secondary supply did not stand up on the D500-B graphics card as a result of a missing enable signal. The +3.3v secondary rail was the only rail that did standup. I tried to perform...
                          12-07-2023, 09:55 PM
                        • obelix24
                          A1534 820-00045 - USB-C not working both sides
                          by obelix24
                          Hi All,
                          I just got one Macbook 12" that was not powering on. I found out that the battery was flat on right side so I charged it little bit with power supply and the MacBook turns on.
                          Problems that I have when I connect everything I can see for second apple logo and it it dims down, then there is apple logo with progress bar also only for second and then dims down. I found that issue is with trackpad (probably keyboard part) as when I disconnect keyboard from trackpad MacBook boots up normally. I took off the black cover on keyboard I was expecting some water damage...
                          11-07-2023, 07:44 AM
                        • Danielreinaa
                          HELP need password bios Macbook A1706
                          by Danielreinaa
                          Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                          Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                          Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                          gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                          Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                          09-07-2024, 03:47 PM
                        • moderator
                          A1706 - emc 3107 bios
                          by moderator
                          a1706 Bios file i am uploading , need cleaned, its not password locked..macbook is booting ..getthing chime also.but stuck on apple logo..in target mode disk is recognised and i was able to copy data...it happened while changing the touchbar
                          Serial number is C02STA7EHF1P
                          its A1706 - emc 3107...
                          05-17-2024, 07:00 AM
