Macbook Pro M1 13" NO display PP3V3_S2 issues
+ More Options
Posts
  • oxonater
    • Oct 2012
    • 77
    Hi peops
    Ok I find myself on here once again trying to find a solution to my issue/problems with this device, basically I reckon I messed it up but trying to correct this issue.
    Bascially device was working fine however I stupidly in my complete ignorance was putting back together and some how connected an M2 TRACKPAD which are clearly not compatiable. After I realised what I did the damage was done NO DISPLAY / No Keyboard caps lock light so I am like WTF I have i done idiot !!!!
    After some scratching around I did some measuring and found that PP3V3_S2 connections where shorted to ground, having removed most of these components to further make life difficult for myself I am left still puzzled and wondering what could of blown/broke.
    The strange thing is even with all the corresponding PP3V3_S2 components removed I still have a short and in particular UT105 Pin 3 is still shorted to GND !!
    Well hope someone can save me from this mess apologies I have no measurements per say just probing here and there hoping for the best LOL
    Thanx in advance OXY
  • mon2
    • Dec 2019
    • 14399
    What is the 820-**** of your logic board?
    What is the voltage and current draw on your usb type C meter when connected to this logic board?
    • oxonater
      • Oct 2012
      • 77
      Hi thanx for the response
      Board is 820- 2020 which is m1 13"
      Voltage from the meter now just bare board is
      5.11v
      0.001A
      00005mA0000
      was booting and that before I decided to remove components.
      was wondering if the source of the problem was u8100 I believe this controls the voltages.
      Poss fighting a losing battle here though I do recall a electrical burn smell after realising what I had done such a fool.
      we live an learn I suppose hopefully!
      Thanks again Oxy
      • mon2
        • Dec 2019
        • 14399
        The current draw is @ ~1 mA which is extremely low.
        What is the voltage to ground of PPDCIN_USBC_AON ?
        • oxonater
          • Oct 2012
          • 77
          Measured PPDCIN_USBC_AON and coming out on meter as 5.14v
          Also note that CC721 PPBUS_AON_3V3S2_VIN_ISNS is shorted to ground in continuity mode
          Thanx Oxy
          • oxonater
            • Oct 2012
            • 77
            Ok so bit the bullet an removed u8100 as found other shorts around the WIFI chip, of course all shorts gone typical.
            So got plenty of spare boards that are MDM so know they work will source the stencil and use a donor thanks for you help much appreciated 🙏
            • Flasman90
              Macbook Pro DFU Restore Issues
              by Flasman90
              I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
              - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
              - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
              08-30-2025, 10:27 AM
            • cheebster
              Macbook Air 2020 A2179 Internet Recovery and Battery Issues
              by cheebster
              Hello, i have a batch of 10 Macbook Pros A2179 bought from a Costco return wholesaler.
              The 10 of them show the exact same behavior;
              They auto power on, to internet recovery spinning globe, fans to 100%.
              Power consumption on USB-C port is 0.43a, shuts down as soon as unplugged. Battery doesn't charge at all. However, it boots to 20V on the Ampmeter.
              Based on their iBridge versions (4.x and 5.x) these were shelfed for a long time.
              All of them power on the same way; 100% fans, shut down as soon as they are unplugged. Removing...
              10-09-2024, 06:23 AM
            • itzusman
              1708 EMC3164 macbook have power issues
              by itzusman
              Hi Masters.
              My 1708 EMC3164 macbook have power issues. First it was working fine but a bit slow in booting. Net day i turned it on and it didn't powered on. And i tested with usb meter it suddenly @ 20v it takes 2.6 ampares and cpu gets hot. Then i checked the baord and PPBUS_G3H was short to ground. I injected 1v to it it takes 350ma and cpu gets warm. After opening L7410/20/30 there was inly L7420 line was short then i injected 3v to PPBUS_G3H and it takes 2.5 amps and U7420 got hot and i desolder it. Now after that in the start it takes 0.580 amps and goes to 620-30 mili amps....
              07-13-2024, 06:19 AM
            • envym
              MacBook Pro 2018 with Activation Lock
              by envym
              Hi everyone!
              I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
              I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
              06-27-2025, 08:54 AM
            • tobeend
              Bypass mdm macbook m2 ventura
              by tobeend
              1. RESET MACOS WITH IPSW
              a. Power off MacBook, press and hold the power button to enter Recovery
              b. Open Disk Utility, remove Macintosh HD
              c. Reboot, connect to the network to Activate Mac.
              d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
              d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
              e. Release the other keys, but keep holding the Power key for another 10 seconds
              f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
              05-26-2023, 07:18 AM
