Hi to all, I hope someone can shed some light on a laptop issue I am having. It is a Lenovo Ideapad 100-151BD. It came in as "no display". Removed and re programmed Bios chip. Laptop now does power on, but take a few minutes to display anything. Once booted it works perfectly. Battery is charging as normal. Speed is good for what it is...I even managed to update the bios with the latest from Lenovo. Still issue persists. Any ideas?
Checked BIOS battery. 3.2v. Lan, WIFI all USB working correctly. It is only on the startup that there is a delay. After boot takes place it is perfect. Successfully installed Windows and all drivers. Once booted everything is perfect... It almost seems as though something needs to heat up before progressing...
Late display is 'coz of dirty me region. If you dont know how to extract bios from update file.then post a request in the bios subforum for a clean me bios.Remember to upload your existing bios. No point troubleshooting lan,card reader etc at this stage.Comment
THANK YOU!!! Mcpisig123 you are indeed a Badcaps Legend. Done a ME Clean and worked perfectly. Thank you so much! Attached is the working file for everyone else...Comment
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM -
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by mximiliandzGood morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by grimacelordHello there.
History:
I searched for this error online and discovered...-
- Loading...
