Help with Lenovo P52 - no charge, no power on
  • nemitom
    • Česko
    I have problem with Lenovo P52. (I7 - 8850H)
    On battery is not problem - work normal
    On external power supply - after connect only one-shot blink white LED and no start...
    Power supply is ok, battey is ok
    Where to start measuring? Is this a common error?
    Thanks All.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Voltage on Source/Drain/Gate of dc-in mosfets? Only power adapter connected.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • ipatch
      troubleshooting microsoft surface pro 4 no power no led charge light
      by ipatch
      hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
      10-05-2023, 11:59 AM
    • proxneo
      iPad A2197 no power, A10 and other IC become warm, only 0.5A charge
      by proxneo
      Dear reader
      TL;DR: iPad not turning on, A10 and power IC become (very) warm when attempted to turn on but this power-on cycle has a 'cooldown' period wherein powering on doesn't work, does not take more than 0.5A charge.
      I am working on an iPad 7th generation 2197 from >2019 with no / limited charging and no boot issues. It is a refurbished purchase made in 2021. It appears the 'refurbish' company has either done prior motherboard work (all protective component shield layers are gone) or is one of the many trash refurbish companies (little screen adhesive left, component...
      12-01-2023, 04:14 AM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
