DAG75AMBAD0 REV D
  • tomimc
    • Jul 2015
    • 9
    • spain
    DAG75AMBAD0 REV D
    The screen turns on late, the fans spin at high speed and the device turns off.
    i tried to change the rt8816A as in post https://www.badcaps.net/forum/troubl...75ambad0-rev-d a user fix the problem
    The motherboard has two 8816a, PU9009 -> FBVDDQ_MEM to power graphic memory and PU9006 -> NVVDDS. I changed both. The issue is the same.
    If i move to UMA works ok
    High Pressure Sodium Yard light when air conditioner turns light momentarily turns of
    I have had these 70 watt high pressure sodium yard lights for many years now probably at least 15 years or more and there is a protection diode that after several years starts to go bad and when it does this it has momentarily shutting down the light and then a few minutes later it starts working again
    This about the forth time I have fixed this one and you can tell if it the diode or not if it lights up and it only shuts down when the air conditioner turns on then it is the diode
    If it cycling on and off constantly then it is the bulb itself that is the issue
    06-03-2023, 05:24 PM
  • Gigabit2
    MacBook Pro Mid 2012 turns on, fans spin for five seconds and turns off, repeats
    by Gigabit2
    I have a MacBook Pro Mid 2012 with 820-3330-B board.
    The laptop shows a green light on the charger, turns on and the fans spin for about five seconds. Then it turns off and this repeats over and over.
    Before it turns off, the SuperDrive (DVD/CD drive) makes a noise like it does when it first turns on from cold (on a working machine).
    I am stumped, can anyone help?
    06-22-2022, 09:29 AM
  • Stephen
    A1466 MacBook Air 13" 2017 Backlight issue works but then turns off
    by Stephen
    Hello, got a weird MacBook Air here
    board looks fresh and no water damage, backlight works and turns on and stays on when installing OS etc. However, when the os is installed and when the system files are loaded before the login page the backlight goes out. I have wiped it, NVRAM reset, etc and even took some other instances and this blows my mind, never seen this before. Backlight just turns off once the OS is loaded. Anyone come across this and if so what would be the cause? I am certain its a board issue since I tested the LCD on another board and it stays on. Again the backlight works...
    08-23-2023, 09:12 AM
  • marce002
    Macbook A1465 works fine Linux but turns off in MacOS
    by marce002
    Hello
    I have this macbook Air 11 inch, was working fine with macos,,, then suddenly turns off by itself after apple logo screen.....it cant boot...
    Formating and installing does not work because it also turns off.....
    But: booting linux ubuntu from pendrive and also installing it in ssd works fine!! hours and hours, the macbook runs fine and fast and cool....
    So she does not like MacOS , loves Linux... can this be related to EFI? I have tried booting macos with shift pressed and allow me to login but even in this safe mode it turns off itself with...
    02-02-2022, 05:43 PM
  • reset1986
    MacBook A1278 main 820-2530b not charge, it turns on only with battery
    by reset1986
    hi, I have this macbook that works correctly with battery inserted, if I connect the power supply the light turns green but it does not charge, if I disconnect the battery and connect only the power supply the light turns green and the mac enters the ignition loop 4/5 sec, turns off and repeats itself,
    on the motherboard there are no traces of liquid or damaged components,
    I tested the 3.42 and they are constant both with power supply and with battery,
    advice on what signs I can start checking?
    the power supply indicator light never turns orange,
    power...
    10-26-2021, 02:46 PM
