Macbook A1707 - 820-00281 - No Power
  • saisoni20
    • Feb 2022
    • 111
    Hi Everyone,
    I have one MacBook Pro A1707 - 820-00281 No power. USB-C meter is showing 19V - 0.05A.
    There is nothing short to ground. Voltages are as below.
    PPBUS_G3H - 12.62V
    PP3V3_SUS - 3.3V
    PP3V3_S5 - 3.3V
    PP3V0_G3H - 0V
    PP5V_PMICLDO - 5V
    PP3V3_S5 - 3.3V
    PP1V8_SUS - 0V (0.6M)
    PP3V3_S0 - 0V
    PP5V_S4 - 0V (6k)
    EN missing for PP5V_S4.
    Is it looking like PCH not turning on?
    Someone can help me?​
  • leonemax81
    Macbook a1707 820-00281 Battery no Power
    by leonemax81
    Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
    08-23-2024, 09:24 AM
  • sofles
    Macbook a1707 2017 model 820-00928 GPU issue
    by sofles
    Hello there
    I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
    I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
    11-21-2024, 05:25 AM
  • tommy97
    Apple MacBook A1707 No Audio/Sound
    by tommy97
    I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
    I've also replaced U6300, but the problem persists.
    Here are the current voltage readings:
    • PPV18_S0: 1.8V
    • R6402: 1V
    • R6405: 1V
    • R6403: 1V
    • AUD_SPKRAMP_RESET_L: 1.3V
    • PPBUS: 12.6V
    03-10-2025, 11:22 AM
  • Cemal Odabasioglu
    MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
    by Cemal Odabasioglu
    I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
    Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
    Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
    Observations...
    01-14-2025, 03:54 PM
  • Instafixx
    Macbook A1707 820-00928 Panic Log
    by Instafixx
    Namaste!
    We have a Macbook A1707 which came in for repair. Someone had already tried to work on it and there were traces oh heat and burns on the board.
    The charger was Stuck at 5v and the there was some caps shorted around U3100.
    Turns out there was corrosion under U3100. Same was Reflowed and the Macbook turned on. Works fine but having 1 issue whenever the Macbook is idle and goes into sleep mode. It will WAKE for 1 Second and then do a restart.
    It will Display a Black Screen with error message saying Macbook Restarted because of a problem....
    01-19-2023, 04:15 AM
