MacBook Air 2018 A1932 820-01521 stuck at 5V, but succesfully does the DFU and boots into OS installer
  • mitchw
    • Dec 2016
    • 136
    • Slovenia
    I have a 820-01521 that is stuck at 5V, and drawing just 230mA.
    I did some troubleshooting, and managed to charge the battery up (was at 0%) using a different logic board.
    Also I ran DFU and it did it successfully. Had to use a PMU_FORCE_DFU jumper to do it.
    At this point the laptop started up and it successfully boots into the OS Install.
    The charger is now at 20V, but drawing 0mA, so the laptop is essentially running off the battery. It doesn't detect the charger...
    I think there could be a problem with one of the CD3215s, but all the LDOs are there...
  • mon2
    • Dec 2019
    • 14265
    MacBook Air A1932 Not turning on, pulling 0.03-0.06A at 20V repair - Repair Wiki
    • mitchw
      • Dec 2016
      • 136
      • Slovenia
      I'll check it out, thanks.
      Anyways, if I have battery connected, it gets to 20V, but stays at 0mA.
      With battery disconnected, it only gets 5V, but draws 230-240mA.
      • mon2
        • Dec 2019
        • 14265
        Review the attached mosfets that are between the CD3215 and the PPBUS_G3H rail. Remove all power. Meter in resistance mode.
        Check the resistance of each mosfet -> check source & drain; source & gate; gate & drain for each of the dual mosfets. That is, you have 2 mosfets in a single package so each is a suspect.
        • mitchw
          • Dec 2016
          • 136
          • Slovenia
          Both measure the same.
          Found next (possible problems):
          - PPBUS_G3H is 12.3V (should be 12.6V I think)
          - PP3V3_G3H is 3.3V
          - PP5V_G3S is 0V
          - PP1V8_G3S is 0V
          No shorts on those two, which makes sense as the laptop worked fine on battery when booted to OS install after DFU.
          On battery of course there are all voltages present...
          I also did another quick check of the LDOs of the CD3215s.
          All of them are fine, except there is a bit strange behavior of the PP1V1_UPC_XA_LDO_BMC and PP1V1_UPC_XB_LDO_BMC voltages:
          If the charger is connected to the U3200 USB-C ports (the closest to the screen)
          - PP1V1_UPC_XA_LDO_BMC is 0V
          - PP1V1_UPC_XB_LDO_BMC is 1.1V
          But if I connect the charger to the USB-C port that is connected to U3100 (the closest to the trakcpad), then I get the following:
          - PP1V1_UPC_XA_LDO_BMC is 1.1V
          - PP1V1_UPC_XB_LDO_BMC is 0.98V
          Is that correct? If not, then which CD3125 is misbehaving? I sadly don't have a known good board to verify this
          • mon2
            • Dec 2019
            • 14265
            When you measured the bmc_ldo rails, did you rotate the usb type C connector?
            review this guide on how the cd3215 devices work to select the 20v power delivery contract.
            https://logi.wiki/index.php/CD3215_Bootup_Sequence
            • mitchw
              • Dec 2016
              • 136
              • Slovenia
              I did rotate them
              • mon2
                • Dec 2019
                • 14265
                PP1V1_UPC_XA_LDO_BMC should also be 1v1 when used as the active port.
                check each ldo in diode mode. Remove all power. Meter in diode mode. Red meter probe, yes red to ground. Black meter probe to the ldo rail under test.
                post each measurement of each ldo rail on each cd3215.
                • mitchw
                  • Dec 2016
                  • 136
                  • Slovenia
                  Here you go:
                  PP1V1_UPC_XA_LDO_BMC: 0.550V
                  PP1V1_UPC_XB_LDO_BMC: 0.550V
                  PP1V8_UPC_XA_LDOD: 0.512V
                  PP1V8_UPC_XB_LDOD: 0.511V
                  PP1V8_UPC_XA_LDOA: 0.554V
                  PP1V8_UPC_XB_LDOA: 0.553V
                  PP3V3_UPC_XA_LDO: 0.525V
                  PP3V3_UPC_XB_LDO 0.525V
                  Both read exactly the same...
                  ... on the logi.wiki it says: PP1V1_UPC_XB_LDO_BMC (On active port after reading TBT ROM). So that means if I get a 0.98V on inactive port, and 1.1V on active, that the inactive is dead? Connected other way around, I do get 1.1V on active and 0V on inactive...
                  • mitchw
                    • Dec 2016
                    • 136
                    • Slovenia
                    Anyways, I replaced the U3200 (the most likely suspect) and the board is working now
                    • pepebmx
                      ThinkPad T14 Gen 3 - Boots Only on Charger
                      by pepebmx
                      Subject: Lenovo ThinkPad T14 Gen 3 - Boots Only on Charger, Fan Spins Full Speed with Battery
                      Laptop: Lenovo ThinkPad T14 Gen 3
                      Serial No: PF-437QTG
                      PCB: NM-E441 Rev 1.0 (JT4C1/JT6C1/JP6C1)
                      Extracted BIOS: Will upload tomorrow
                      BIOS Password: None Issue Description:
                      • Boots only on charger → Works normally when connected to AC.
                      • With battery connected:
                        • Fan spins at full speed, no display.
                        • Not all voltages present (some missing).
                      • Battery charges correctly (detected in Windows, shows percentage).
                      • When battery is plugged in while in Windows:
                        • Laptop shuts
                      05-08-2025, 01:53 PM
                    • bouch
                      unlock macbook air A1932 2019
                      by bouch
                      hi
                      i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                      i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                      i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                      have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                      I need help or information?
                      Does anyone have the minat2 activator 1.4 software?
                      Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                      Thank yo...
                      03-12-2025, 10:14 AM
                    • astroboypaul
                      Macbook A1932 Some Keys Not Working
                      by astroboypaul
                      Macbook A1932 had completely dead keyboard. I found liquid damage on circuitry on keyboard itself, and repaired it by replacing what i think was a 10k 0201 resistor (here's my post requesting schematic for keyboard circuitry where I included a photo of the resistor: https://www.badcaps.net/forum/troubl...ic-820-01294-a)
                      Now most of the keyboard works and I can login, but the following keys don't work: Delete, "/', left...
                      06-10-2024, 05:32 AM
                    • abajor
                      A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
                      by abajor
                      Having this very weird issue.
                      The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
                      I swapped with a working screen from an A2141 waiting for parts.
                      The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
                      The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
                      04-27-2024, 01:37 PM
                    • astroboypaul
                      MacBook Air A1932 Keyboard Schematic 820-01294-A
                      by astroboypaul
                      Can anyone help with a schematic and board layout for the keyboard 820-01294-A in Macbook Air A1932 please? (for reference, mainboard is 820-01521-A)
                      Alternatively, I'd settle for confirming value of a resistor on the keyboard (red arrow in picture below)
                      Water damage keyboard, with corrosion visible on the noted resistor (picture was taken after cleaning). One pad under the resistor was corroded and resistor fell off while clearing the potting resin (or whatever it is Apple has coated the components in).
                      By chance I discovered that mainboard 820-02443 has...
                      03-22-2024, 11:57 PM
