Macbook Pro a1990 820-01041-A no power draw
  • dj0nes
    • Jan 2024
    Hello, I'm new to this level of troubleshooting (had not heard of openboardview 30 minutes ago), but have a multimeter and just found the schematic for this mainboard (820-01041-A).
    Board & battery were replaced by Apple late 2021, stopped working late 2022 after sitting on a shelf for a while, and haven't touched it since. Did some googling for similar posts, and tested these voltages with the laptop plugged in. I only moved the charging cable to a different port for testing PP20V_USBC_TB_VBUS, not sure if that's relevant.
    • PPBUS_G3H@F7000 (asked for here on a similar post) is showing 12.28v, but no draw (.3w) at the wall outlet.
    • PP5V_G3S@J6000 is exactly 0v (mentioned here, as are the following ports)
    • PP3V3_G3H_T@C7669 is 3.3v
    • PP20V_USBC_TB_VBUS@TP1 is 5.15v when the charging cable is plugged into the lower port on that side. Otherwise 0v.
    • PP3V3_G3H_RTC_X@TP1 is 3.3v
    I'm guessing that PP5V_G3S is sus, but not sure what to do next. Thank you in advance for any help!
  • survivalbloke
    Macbook Pro A1990 - no power/ no draw
    by survivalbloke
    This device has logicboard# 820-01827. I couldn't find a schematic and bv for that one, so I am using a similar one, the 820-01041 which seems identical actually. Anyway I'm stuck on my troubleshooting, so let me take you through where I've been and where I am now and hopefully I can get some guidance. Initially the device was stuck on 5v.
    I found C6503 shorted which is PPBUS_G3H. I injected 1v to reveal U7660 heating up. I replaced U7660 and that short/problem went away. (see images c6503, u7660).
    After this I was getting 20v, but still no power draw/power on. I...
    10-17-2023, 11:11 AM
  • alfredodinolfo
    MacBook Pro 2019 (A1990)
    by alfredodinolfo
    mb code:820-01827-A;
    sn:C02Z349ALVDR;
    i9 32GB Ram 1TB
    Hi, I found short on one of 6 black nand (total 1TB).
    i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
    I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
    macbook with A2141 configuration run on recovery but don't complete it.​
    anyone can help me?
    05-26-2025, 09:27 AM
  • robka
    MacBook Pro 2018 - A1990 Dead - not charging - only 5V
    by robka
    my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
    I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
    The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
    After that the Macbook was dead. It isn't charging anymore.
    The USB-C Port where the charger was plugged is burned. Also The Cable and the...
    03-02-2024, 02:58 PM
  • DATATECH85
    Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
    by DATATECH85
    I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
    The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
    I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
    However, I can't work out exactly why I don't have the PPBUS_G3H rail.
    Here are the values...
    07-24-2024, 06:34 AM
  • npielawski
    MacBook Pro late 2016 (820-00239) with multiple failure modes.
    by npielawski
    I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
    I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
    10-15-2025, 01:53 AM
