HP 15-be002tu BDL50 LA-D702P Rev 3.0 Power's On But No Display!
  • m041633n
    • Oct 2020
    • 21
    • india
    Tried Flashing the Bios from HP Website with CH341a Programmer
    (Extracted the BIN File using HP's "Copy BIOS image in order to use it on other devices" option)
    Tried the First One 081EC From the 5 BIN file's (081EC, 081ED, 081EF, 081F2, 081F3) which was extracted and decrypted already with the BIOS Update Utility from HP.
    But still the Same issue
    the Laptop's powering up, the HDD is not spinning nor the hdd led is blinking nor the Caps Lock led is blinking nor the cpu is heating, there is no display! Cleaned the RAM and the RAM Slot with IPA. Tested powering up the Motherboard alone without connecting any of its spares but still no luck.πŸ˜›
    No RAM Beeps! πŸ˜€
    I will be happy 😊 if someone 😌 could help me on this issue! And it's very urgent! Thank you 😊 πŸ’“ ☺️
  • mon2
    • Dec 2019
    • 14205
    HDD not spinning is of concern. Test on another machine to confirm the drive is not defective.
    Is it a SSD or a mechanical hard disk drive? Disconnect from the logic board and test again.
    • m041633n
      • Oct 2020
      • 21
      • india
      Hi I've Explained you everything in the post
      • m041633n
        • Oct 2020
        • 21
        • india
        Tried removing these things from motherboard and turned on
        HDD (HDD is working fine on a different computer and its intact.), CMOS Battery, Ram, all the flex connectors, WiFi Card, Battery, including the power button flex cable (shorted the power button connector on the board to turn on) still no display! Connected the display cable only for display.
          • 20908
          The 15-be002tu has a Braswell (BSW) N3710 CPU -> https://support.hp.com/au-en/document/c05161809
          The 081EC bios has ME 11 firmware,so it is the wrong bios. Check all of the 5 extracted bios with ME Analyzer ,the chipset support should say BSW/CHT
          Click image for larger version  Name:	Capture.jpg Views:	0 Size:	104.3 KB ID:	3171171
          • m041633n
            • Oct 2020
            • 21
            • india
            Tried it! But it didn't work πŸ˜• πŸ˜ͺ
            It's still the same.
            Checked the Old Bios Backup with ME Analyzer it says BSD/CHT on the chipset support and checked the New BIOS 081F2.BIN it was matching the same chipset support
            How to start checking with the multimeter on which component with what settings on the multimeter. I don't know component level checking. It would be better if someone has the same board and same issue like mine and explain how did they resolved it. Please Help 😊 desperate to solve this case.
            😊 Thank You 😊
            • m041633n
              • Oct 2020
              • 21
              • india
              Any solution πŸ˜‰??
              • m041633n
                • Oct 2020
                • 21
                • india
                Any help
              • m041633n
                • Oct 2020
                • 21
                • india
                On which component SMDFlea?? I am really sorry 😞 that I irritate Professionals like asking these silly questions. Would you Please help me on this?? Thank you SMDFlea.
                BTW I didn't flashed the SIO and I don't know how to flash the SuperIO using CH341A Programmer. Can you guide me on this please I don't have the Keyboard Flex Cable
                Thank You SMDFlea!
                • m041633n
                  • Oct 2020
                  • 21
                  • india
                  I tried reading the SuperIO ENE KB9022 Using CH341A But the IC Was not detecting! In neo programmer using these
                  pinouts
                  KSO3 GND PIN 4
                  KSI4 CS PIN 5
                  KSI5 CLK PIN 6
                  KSI6 MOSI PIN 3
                  KSI7 MISO PIN 2
                  Please Help me. I tried reading in TL866II βž•οΈ ICSP with no SPI DRIVER HEADER. But it shows only zeros. What should I have to do??
                  • m041633n
                    • Oct 2020
                    • 21
                    • india
                    Please help??
                    • m041633n
                      • Oct 2020
                      • 21
                      • india
                      Are the Connections are correct πŸ€”
                      • jose6326
                        Samsung s32d850t powers off
                        by jose6326
                        Powers on as normal shows an image then powers off after 10 seconds
                        I have to unplug it from the wall and replug to get it to turn back on but then shuts off
                        No blown caps
                        I searched for this model but nothing comes up...
                        11-29-2024, 11:21 PM
                      • valvashon
                        LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                        by valvashon
                        The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                        Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                        11-24-2024, 12:08 PM
                      • trix11
                        Dell Precision T1650 MT Workstation bricked after BIOS update
                        by trix11
                        I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                        - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                        - Dell Precision T1650 mid tower Workstation
                        - Xeon E3-1225 V2
                        - 32Gb PC3-12800E RAM
                        - 4Tb SATA HDD
                        - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                        I see now that others have experienced like issues e.g.:
                        - https://www.dell.com/community/Prec...
                        10-24-2022, 10:35 PM
                      • AkaBukai
                        Is it okay to flash stock bios onto the motherboard's BIOS?
                        by AkaBukai
                        Hi there,
                        I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
                        The little LED on the power button is flashing slowly and nothing happen.
                        This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
                        So I decided to flash the BIOS using a cheap programmer.
                        And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
                        I also...
                        12-19-2024, 12:15 PM
                      • simwalsh
                        Philips 47PFL4606 Powers on, works normal then powers off after a minute
                        by simwalsh
                        I am new to this forum and have searched for some answers with problems similar to mine.
                        Philips TV powers on as normal for about a minute or less then click and no power at all not even standby light. If i disconnect from mains and reconnect it will power on again but for a shorter time. Once i leave it disconnected from main for a longer time it will power on for a longer period the next time.
                        It sounds like a power supply issue?
                        I have the board out and want to run some tests. Not sure what i should be doing but i put a 1k resistor across SB and +5v...
                        12-04-2023, 04:03 AM
