HP 15-be002tu BDL50 LA-D702P Rev 3.0 Power's On But No Display!
  • m041633n
    • Oct 2020
    • 21
    • india
    Tried Flashing the Bios from HP Website with CH341a Programmer
    (Extracted the BIN File using HP's "Copy BIOS image in order to use it on other devices" option)
    Tried the First One 081EC From the 5 BIN file's (081EC, 081ED, 081EF, 081F2, 081F3) which was extracted and decrypted already with the BIOS Update Utility from HP.
    But still the Same issue
    the Laptop's powering up, the HDD is not spinning nor the hdd led is blinking nor the Caps Lock led is blinking nor the cpu is heating, there is no display! Cleaned the RAM and the RAM Slot with IPA. Tested powering up the Motherboard alone without connecting any of its spares but still no luck.πŸ˜›
    No RAM Beeps! πŸ˜€
    I will be happy 😊 if someone 😌 could help me on this issue! And it's very urgent! Thank you 😊 πŸ’“ ☺️
  • mon2
    • Dec 2019
    • 14725
    HDD not spinning is of concern. Test on another machine to confirm the drive is not defective.
    Is it a SSD or a mechanical hard disk drive? Disconnect from the logic board and test again.
    • m041633n
      • Oct 2020
      • 21
      • india
      Hi I've Explained you everything in the post
      • m041633n
        • Oct 2020
        • 21
        • india
        Tried removing these things from motherboard and turned on
        HDD (HDD is working fine on a different computer and its intact.), CMOS Battery, Ram, all the flex connectors, WiFi Card, Battery, including the power button flex cable (shorted the power button connector on the board to turn on) still no display! Connected the display cable only for display.
          • 22119
          The 15-be002tu has a Braswell (BSW) N3710 CPU -> https://support.hp.com/au-en/document/c05161809
          The 081EC bios has ME 11 firmware,so it is the wrong bios. Check all of the 5 extracted bios with ME Analyzer ,the chipset support should say BSW/CHT
          Click image for larger version  Name:	Capture.jpg Views:	0 Size:	104.3 KB ID:	3171171
          • m041633n
            • Oct 2020
            • 21
            • india
            Tried it! But it didn't work πŸ˜• πŸ˜ͺ
            It's still the same.
            Checked the Old Bios Backup with ME Analyzer it says BSD/CHT on the chipset support and checked the New BIOS 081F2.BIN it was matching the same chipset support
            How to start checking with the multimeter on which component with what settings on the multimeter. I don't know component level checking. It would be better if someone has the same board and same issue like mine and explain how did they resolved it. Please Help 😊 desperate to solve this case.
            😊 Thank You 😊
            • m041633n
              • Oct 2020
              • 21
              • india
              Any solution πŸ˜‰??
              • m041633n
                • Oct 2020
                • 21
                • india
                Any help
              • m041633n
                • Oct 2020
                • 21
                • india
                On which component SMDFlea?? I am really sorry 😞 that I irritate Professionals like asking these silly questions. Would you Please help me on this?? Thank you SMDFlea.
                BTW I didn't flashed the SIO and I don't know how to flash the SuperIO using CH341A Programmer. Can you guide me on this please I don't have the Keyboard Flex Cable
                Thank You SMDFlea!
                • m041633n
                  • Oct 2020
                  • 21
                  • india
                  I tried reading the SuperIO ENE KB9022 Using CH341A But the IC Was not detecting! In neo programmer using these
                  pinouts
                  KSO3 GND PIN 4
                  KSI4 CS PIN 5
                  KSI5 CLK PIN 6
                  KSI6 MOSI PIN 3
                  KSI7 MISO PIN 2
                  Please Help me. I tried reading in TL866II βž•οΈ ICSP with no SPI DRIVER HEADER. But it shows only zeros. What should I have to do??
                  • m041633n
                    • Oct 2020
                    • 21
                    • india
                    Please help??
                    • m041633n
                      • Oct 2020
                      • 21
                      • india
                      Are the Connections are correct πŸ€”
