Mac T2 after update(There was an error activating your device)
  • TechSplendid
    • Oct 2023
    • 14
    • Gelderland
    Again, thank you!
    But when I read above I read that this is not working due to a bridgeos update. That makes it a bit confusing for me.​
    • curiositymaster
      • Apr 2021
      • 45
      • Nigeria
      Originally posted by TechSplendid
      Again, thank you!
      I’ve had two instances where the Mac got locked the to the preexisting iCloud on the new serial.
      1. The Mac was restored on AC (because it couldn’t power on after changing serial). After restoration, it asks for activation and it suddenly brings an iCloud account that was never associated with the original serial.
      2. The user already updated the system to latest MacOS version but wants to remove his information before selling. After he signed out his own iCloud information and wants to erase the mac from system settings, it was asking for another iCloud account which was never used on the system.
      I think Apple patched something in the T2 that forces the device to use iClouds linked to any serial number.
      if someone has a T2 Mac, they could verify if my observations are correct or mere coincidence.
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 667
        This is not the case, if you got this computer from the customer and it wanted the iCloud removed and another showed up, this means the computer was bypassed, iCloud information is not stored on the serial number it is stored on the T2 chip. The serial only has to match for the T2 chip to verify with the server, however the serial has nothing to do with activation, it has everything to do with the T2 chip. FOR example, if a company has an MDM lock on the device, they never sign into the T2 chip or register it because it is tied to just the serial hence changing the serial will result in a free and clear Activation, this means if you change the serial and it gives an error, this device was bypassed or the iCloud was never removed from the T2 chip itself.
        sigpic
        MEOWING IN THE IMPOSSIBLE UNIVERSE!
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 667
          Update: the serial number I checked was just rejected. It appears you have to use VALID serial numbers from Apple now. Ill update with my findings soon
          sigpic
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 667
            Ok I figured out what is going on with your issue. So Apple has indeed changed some way to remove the MDM, but however it is not as crazy as you believe. Upon further investigation we have a normal customer that purchases pallets from schools etc with an R2 certification however, they understand that they cannot bother the companies with the removal of MDM if they fail to remove it (per rules of their contract) the process would then move to our shop, we just got a batch of computers that had MDM locks on them, inspecting the serials they are indeed locked however we will not contact that company, the best process is indeed changing the serial, however it was easy to just change the last digit or a few, but you did need to match the model and year for the computer to look correct and function as intended, but what I did discover is that if you use any serial back in the day that matched the model it would activate on Apples servers, HOWEVER moving forward you should check those serials moving forward to verify they are pulling on Apples Servers now, if they reject, they are either reported as STOLEN, LOST, or NOT VALID. SO what that means is you need to use a VALID serial that is iCloud locked or not (that is not MDM locked) you will have to check a few things to plug in the correct serial, and then the next process is sadly, you will have to RESTORE the computer through DFU to register the serial correctly with the T2 chip, yes the T2 chip is the first check for iCloud activation, however the Apple serial is the final check for the server to verify its legitimacy that it is an Authentic serial. So moving forward you will need to do these steps in order for the computer to function correctly. I just spent a few hours to figure out the new process, so go ahead and PIN this for your findings and process. Hope this helps.
            Here is a break down how to achieve this:
            1. MDM is discovered locked (IE: A1990 MacBook Pro 15" 2018)
            You will need to get a serial that matches this exact year and model, you can change a few digits but make sure they pull up on Apples servers, if they do not it will not authenticate. if you get a valid serial, you will need to restore the computer to tie it with the T2 chip.
            2. Change the serial (make sure it is not MDM locked) how you find this out is on you. I cannot disclose all this information because those are paid websites and you will have to figure a way to get it checked, I recommend whatever works for you that costs you little to nothing.
            3. Verify the serial on the servers, check for MDM, and check for FMI to make sure it pulls back. If MDM shows clear, great, if FMI shows rejected, THEN DO NOT USE THAT SERIAL because it will reject on Apples Servers.
            4. Restore the computer with the serial, DFU RESTORE, DO NOT REVIVE. This will bring back the OS install through internet recovery.
            5. Done.
            sigpic
            • curiositymaster
              • Apr 2021
              • 45
              • Nigeria
              #26
              5. Done.
              Thanks so much for your efforts Stephen. I am guessing the serials I used were blacklisted/reported as stolen.
              Checking fmi alongside MDM check is the way to go henceforth.
              • curiositymaster
                • Apr 2021
                • 45
                • Nigeria
                #27
                Those paid web services are now offering serial change by software methods. I have even seen this on the trusted vendors’ website.
                I wouldn’t mind if we could get this software as the one we got for pre-t2 macs, as I believe this will make the process faster and safer.
                • Stephen
                  Meow Meow MEOW!
                  • Apr 2020
                  • 667
                  Those paid web services are now offering serial change by software methods. I have even seen this on the trusted vendors' website.
                  I wouldn't mind if we could get this software as the one we got for pre-t2 macs, as I believe this will make the process faster and safer.
                  Those prices make no logical sense. You can easily just buy a EFI programmer and do the work yourself. Why pay a website something very expensive to do that when it's something that is free if you do it yourself? Obviously as a service you will charge for your labor but this makes no Logical sense to pay these websites for unlocking services to an extent. I can understand paying them for checking IMEI, or FMI, OR MDM etc. but paying them to remove the locks seems unreasonable to me if you have the capabilities in doing it yourself if you have the right tools.
                  Also that software relies on the fact the iBridge isn't updated to do a software MDM removal. I wouldn't rely on software whatsoever.
                  sigpic
                  • jotati7062
                    • Jan 2024
                    • 27
                    • SA
                    #29
                    some info u said Mr Marrtaa GA is not correct, the software is you are talking about to change the serial number cost about 20USD or even less, yeah you can do it for free throw programmer but if you get 13 inch 2020 that could easily take someone 40 minutes, on the other hand with the software it takes two minutes and it's the exact same change, it goes inside the spi rom & replace SN so no difference between software and hardware other than the saving of time and not using a screwdriver
                    The other thing it's possible to change the serial number doesn't matter what BridgeOS your on.
                    im watching u ...
                    • Stephen
                      Meow Meow MEOW!
                      • Apr 2020
                      • 667
                      im watching u ...
                      the rules of posting websites for charges are against the policy. This forum is about teaching people to be able to do the work themselves even if it takes more time. You seem like someone that wants to promote those websites. Those websites are fine for those that want to use it at their discretion, however people are more inclined to do the work themselves without having to pay or use their private info for that type of service. Yes time is money and getting it done quickly is perfectly great, however I think doing it yourself creates a better skill set. MDM locks take time doing it manually but it at least gives some peace of mind you did it correctly. To each their own. Also you’re kind of creepy saying I’m watching you? Go away
                      sigpic
                      • bilel
                        • Mar 2019
                        • 31
                        Originally posted by pehol193
                        Usually i change one letter in SN. It is locked now? I have to unlock MDM from A2251 Macbook pro.
                        Hello.
                        Please how can change serial number of macbook 2019 T2 chip
                        i have one after change serial Number the pc was dead and no power not open and when return backup work perfect bcs i have serial OFF with damged mothearboard i wan t to replace to other new pc to work
                        • gugbobgug
                          • May 2022
                          • 14
                          • Georgia
                          #32
                          if want to unlock icloud you se need change big T2 chip from icloud free mac
                          • Sus256
                            HISENSE 65E7KQ PRO - no boot
                            by Sus256
                            Hi all!
                            HISENSE 65E7KQ PRO
                            RSAG7.820.13512 - chassis
                            MT9618BAATAB - cpu
                            RSAG7.820.12059 - power
                            HD650Y3U77 - panel
                            KLM8G1GETF - emmc
                            The TV does not turn on, the standby indicator is on. All voltages are present.
                            Emms is dead. Not readable, not detected.
                            Replaced emmc.
                            But with another dump there is no launch
                            Terminal log
                            UART
                            AC_ON
                            RPMB key is not yet programmed
                            HASH1_VERSION=0x00000000 64bit
                            E-B
                            FDE enabled
                            layout pattern onebin by SAR7,0...
                            06-01-2025, 02:11 AM
                          • Superbee_dad
                            Sharp 80” long short flash backlight error - Help
                            by Superbee_dad
                            Hello Sharp TV experts
                            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                            01-24-2025, 11:51 PM
                          • rmjimenez455@gmail.com
                            Sumsour station 8586D error H-E
                            by rmjimenez455@gmail.com
                            Hello everyone, next I have the following problem with the Sumsour 8586D 110v dual station I bought it a year ago and it worked wonderfully, now it presents the H-E error on the soldering iron side, the hot air side works correctly..... I disassembled the soldering iron head because the manual tells me that this error is due to ceramic resistance problems, in effect, I measured it and it is open, I bought a new one that is working verified in a soldering iron and nothing.... The same error continues, I proceeded to open the station and check visually, I found a totally damaged 1R00 surface mount...
                            09-07-2024, 09:33 AM
                          • Dannyx
                            Hilti PD30 Laser Range meter Error 276
                            by Dannyx
                            Good day folks.....wow, seems like forever since I posted anything here Still alive and well, thank you I guess you could say I've become more independent and able to work stuff out on my own. This one though goes way over my head and I doubt is fixable, but maybe some bright spark out there has an equally bright idea.
                            So: my Hilti PD30 laser meter quit on me just the other day. It was working fine, I set it down for a while and when I tried using it again it gave me an E276 and wouldn't do anything else. I tried taking out the batteries, all that standard stuff but nothing...
                            07-30-2023, 05:05 AM
                          • ChattFix
                            PS5 Slim Beep No Light UART DDR4 Error
                            by ChattFix
                            Hello everyone, I need some help with a PS5 Slim board EDM-040 that will beep but no light or fan spin.
                            When I connect my bench power supply, (12v 0.500amp) the amps go between .135-.035 then back to .005.
                            When I attach UART I get the error code below. I have replaced the DDR4 ram IC with one from a donor board. Cannot verify is the IC was working or not, still same error.
                            [Slot #] [Date Time] [Error Code] [Priority] [Error Message]
                            00 5/27/2024 4:25:40 PM 80871001 Low DDR4 Error (Power Failure or Short Circuit)
                            |-(OK 00000000 80871001 17554CCE...
                            05-27-2024, 02:51 PM
