Intel i7 10800H downgrade i7 9750H/8750H
  • shahnld
    • Nov 2019
    • 159
    • Netherlands
    Good day Experts.
    Recently i got msi laptop which had a Drmos melted on cpu vcore. i replaced that and the short is gone. laptop starts when pwrbtn is pressed but no display. Capslock not responding(no capslock led ever) so i assume cpu is just bad..
    cpu is getting hot as normal. keyboard backlite works. all voltages are present and in normal range. cpu, gpu fans are spinning..
    I want to replace it but i dont have i7 10800H, i have a donor i7 9750H and 8750H.. the question is any of the 2 i7 8th and 9th gen can work here if replaced with the bad i7 10800H..?? as per specs all 3 cpu has the same tdp, bga socket. only difference is cores and speed..
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Note the marking on each cpu,look for them in cpuworld website and find out the microcode for each of them. Then check your bios for microcode support.If the microcode is supported in your bios,it is likely to work.
    You can look for microcode guidance here
    https://www.badcaps.net/forum/troubl...ocode-guidance
    • shahnld
      • Nov 2019
      • 159
      • Netherlands
      Thanks for your response. i have found same 10th gen cpu on a board long scraped. just took the chance and reballed that.. it just worked. laptop is up and running..
      Cheers
        ASUS VivoBook i7-9750H Notebook Specification for Upgrade or Repair
        This specification for the ASUS VivoBook i7-9750H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the i7-9750H boardview and i7-9750H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS...
        09-06-2024, 12:13 PM
      • xaxex
        HP ZBook 17 Mobile Workstation (not G2) BIOS Downgrade - (Pre-Spectre & Pre-Meltdown)
        by xaxex
        Hi, can someone please help with BIOS downgrade?
        I have recently figured that the meltdown and spectre patches are taking toll on CPU. I know about grc tool but that will only fix the Windows/OS patches. The hardware ones, which are included in BIOS, will still be limiting CPU.
        Currently, the laptop has BIOS version 01.47 Rev.A. I want to downgrade to 01.40 Rev.A which is from January 2018. I am pretty confident that HP had not released patches then.
        All the latest & previous BIOS versions of this laptop are available here:
        http...
        09-11-2021, 01:01 AM
      • Tom_x
        HP Omen 15-dc0001nh capslock blinks 5 long and 3 short
        by Tom_x
        I have HP Omen 15-dc0001nh (DA0G3DMBCE0 rev: E) with blinking capslock 5 long and 3 short. Fans spin constans speed.
        HP worked for 2 months after i repaired (before damaged by thunder via rj45 port) I removed LAN ic and powered on
        Now with blinking capslock:
        All voltage present on big coils, except +VCCGT (i don't know this need for booting)
        I tried re-flash bios with known firmware- same result (now i don't have spare bios chip to test spi flash failure)
        DDR4 ram is ok, tested on other laptop
        WLAN and SSD removed,...
        07-20-2023, 10:10 PM
      • lapfix
        Hp 15 capslock 5 long 3 short pb.
        by lapfix
        Hello friends.
        hp 15 -da009nk ...la-g07cp.
        got this lap with capslock 5 long 3 short.
        Try new dump f.48 still the same.
        try another dump f.04 power on..no display..consumption 0.498..no caps lock blinking.
        ​​​​all voltage are présent.
        pl301/302= 3 and 5 volt.
        pl1001 1.082v.
        pla1 1.033v
        plz1 vcc core 1.058v
        plg1 0v..i think it s the Intel grpahic
        plw1 1.373v.
        plv 3/plv4 vga core 0.918v
        consumption 0.498.
        original bios version f.02..
        any help!...
        02-18-2025, 03:34 AM
      • STKR123
        Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
        by STKR123
        As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
        I wonder if re-flashing the BIOS might be of any use here.
        As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
        There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
        11-03-2024, 06:58 AM
