Acer Aspire ms2271 4810TZ black screen. BIOS?
  • IvanAndreevv
    • Apr 2022
    • 24
    Hello Guys,
    I have a laptop that does not want to boot up. The CPU gets hot, the lights are blinking, but the screen stays completely black.
    I assume that maybe the bios is bricked. Tried to replace the RAM, without success.
    Connected an external monitor to the laptop - again, no success.
    This leads me to the conclusion that maybe I need to install a fresh BIOS.
    Does anybody know where I can download the original BIOS from? I could not find anything on Acer's website, also I am scared to download anything from the web, except from this forum.
    I would be glad if someone helps.
    Best Regards,
    Ivan
    • 21582
    Post a request in the "Bios requests ONLY!" sub forum and someone will help .Post your bios backup and also the laptop serial number
    https://www.badcaps.net/forum/troubl...-requests-only
    • zarabota
      Acer Aspire A717-71G - problem BIOS with keyboard
      by zarabota
      I am experiencing the following issue with my laptop. I have an Acer Aspire A717-71G with a motherboard model C5MMH/C7MMH LA-E911P Rev. 1A. Unfortunately, the original board stopped working, so I purchased a replacement. The new board is the same model but a different revision (Rev. 1B). From what I understand, this should not cause compatibility problems.
      However, the replacement board came with a BIOS version intended for the Acer Nitro 5 AN515-51, which causes the keyboard to function incorrectly. I attempted to reflash the BIOS chip using a CH341A programmer...
      09-03-2025, 01:58 AM
    • mitchw
      HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
      by mitchw
      Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
      After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
      After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
      I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
      04-29-2025, 03:45 PM
    • BlueNitesFire
      I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
      by BlueNitesFire
      So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
      03-08-2025, 03:49 PM
    • Technodoc
      ASUS G614JZ-N3012W Rog Strix need some bios help, laptop black screen
      by Technodoc
      Asus laptop G614JZ-N3012W Rog Strix with i7
      Mainboard G634J-PMV-VGT
      6050A3441302-MB-A01
      2023-02-10
      Power button works okay....power light goes on
      Red "bottom" leds go on
      Charging led works
      Fans do not spin, capslock key does nothing, screen stays black
      I would like to program the bios again, to rule out a corrupted bios.
      However I run into a size error
      The bios chip is a Winbond 25R256JVEN
      Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
      02-24-2025, 04:46 AM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
