Macbook Pro A1707/A1990 tcon
  • tomtom67
    • Mar 2021
    • 14
    I bought an A1707 2017 Macbook Pro for repair.
    One of the high side mosfets for the GPU shorted, and killed the GPU, and, I think, the tcon - display backlight is working with a known good mainboard, but no image.
    I do have a number of physically broken displays, so I have some donor parts.
    I did not find schematic or boardview for the tcon.
    Which chip(s) does eDP signal decoding and needs to be swapped?
    Are there any good repair guides for that tcon out there?
    Best
    Thomas
  • CG_Dionysos
    MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
    by CG_Dionysos
    I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
    • Model: A1707
    • 15-inch, Mid 2017
    • 3.1 GHz Core i7
    • 16 GB RAM
    • Radeon Pro 560
    • 1 TB SSD
    • Board number: 820-00928-A
    I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
    Thanks in advance!
    Greetings from Germany...
    09-16-2025, 06:43 AM
  • alfredodinolfo
    MacBook Pro 2019 (A1990)
    by alfredodinolfo
    mb code:820-01827-A;
    sn:C02Z349ALVDR;
    i9 32GB Ram 1TB
    Hi, I found short on one of 6 black nand (total 1TB).
    i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
    I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
    macbook with A2141 configuration run on recovery but don't complete it.​
    anyone can help me?
    05-26-2025, 09:27 AM
  • leonemax81
    Macbook a1707 820-00281 Battery no Power
    by leonemax81
    Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
    08-23-2024, 09:24 AM
  • robka
    MacBook Pro 2018 - A1990 Dead - not charging - only 5V
    by robka
    my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
    I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
    The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
    After that the Macbook was dead. It isn't charging anymore.
    The USB-C Port where the charger was plugged is burned. Also The Cable and the...
    03-02-2024, 02:58 PM
  • sofles
    Macbook a1707 2017 model 820-00928 GPU issue
    by sofles
    Hello there
    I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
    I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
    11-21-2024, 05:25 AM
