Asus X453MA Rev 2.0 Backlight and fan
  • Christian0734
    • Nov 2020
    • 92
    • France
    I brought an Asus X453MA into the workshop, its owner tells me that it doesn't work on battery despite having replaced it with a new one and that it's making noise. I diagnose and find, firstly, that the fan is constantly running at full speed. Secondly, that the computer works on battery but there's no backlight when the charger is not connected. I look at the screen connector because I see that the adhesive is not holding. I observe that there probably was a short circuit. I isolated everything with hot glue and reassembled it, I don't think it needs to be replaced. The BIOS is in its latest version, everything works normally, the PC doesn't overheat, just the fan running at full speed and the backlight that turns off when the charger is unplugged. The display itself, it works. I inspected the motherboard under a microscope, I saw nothing abnormal, I did not identify any short circuit. Do you have any ideas?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Try replacing the coil marked "100" on the screen card. thats the solution for backlit issue on many asus platforms. Weird but works.
    • Christian0734
      • Nov 2020
      • 92
      • France
      Thank you for this response. Point to consider:
      the screen backlight works on mains power. It also works when an external monitor is connected to the HDMI port in battery mode. The battery is new, and the phenomenon occurs with both the old and new batteries. The computer and display work normally on battery, it's only the backlight in battery mode that does not work. In this case, can we suspect a problem with the inverter or a component on the screen's board?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        This trick works exactly in the scenario you described. backlit works in adapter mode but flicker/not work in battery mode. At the outset i said its weird but works for many people.
        • Christian0734
          • Nov 2020
          • 92
          • France
          Ok, thank you for the information, I will dismantle the screen.
          • Christian0734
            • Nov 2020
            • 92
            • France
            I disassembled the screen, I found three coils with the number 100 (see photo), none of them are cut...
            For the fan, however, it's fixed, it was the NCT7717U thermal sensor that must have acted as a fuse.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              The coils are never broken or cut in this scenario. the smaller coil marked 100 is to be replaced near the backlit controller.
              • Christian0734
                • Nov 2020
                • 92
                • France
                Is there an explanation for this? I am surprised. The photo is misleading, the two coils circled in red in the photo are exactly identical and have the same resistance to current flow 0.2 Ω.
                • mon2
                  • Dec 2019
                  • 14342
                  Post the full top side markings of the nearby backlight IC.
                  • Christian0734
                    • Nov 2020
                    • 92
                    • France
                    The IC on the first photo between the two coils: U2 CM512
                    The other one completely to the left next to the largest coil: U5 CM509A​
                    • mon2
                      • Dec 2019
                      • 14342
                      The following website (translated) states the cm509A can be replaced with a Richtek:
                      https://monitor.net.ru/forum/threads/679804/
                      • Christian0734
                        • Nov 2020
                        • 92
                        • France
                        Thank you for the message. I do not plan to change the integrated circuit. It was only a matter of coils in the message from "mcplslg123". However, do you think that if the backlight does not work on battery but does work on mains power, could it be due to U5?
                        • mon2
                          • Dec 2019
                          • 14342
                          To me, the coil does not sound like the solution since it is only a piece of wire. Respectively, the suspect is more likely the switching regulator and the quality of the design. Never heard of CMI semiconductor before this thread. My bet would be more on the actual backlight led IC and that should fire up every time and not be flaky with the selection of the inductor onboard nor the power path. Just my 2 bits.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            I'll still bet for the coil marked "100". Search for threads within this forum about asus backlit and see for yourself it worked for so many people. I had success with this method on 2 times in asus.
                            • Christian0734
                              • Nov 2020
                              • 92
                              • France
                              Yes, indeed, I have browsed through the forum and found what you were talking about. However, I can't seem to identify which coil is being referred to. I have three where it is marked "100"
                              • mon2
                                • Dec 2019
                                • 14342
                                These parts are very inexpensive. Replace all 3 of them. Also consider to source the replacement component from Richtek if available to you from Aliexpress or similar. Suggest to measure the pad to pad spacing of the inductor pad / width of the inductors for the proper replacements. You will need to flux and apply proper heat with low air pressure to remove each such inductor.
                                • Christian0734
                                  • Nov 2020
                                  • 92
                                  • France
                                  It's not so much about the cost of the component, but the shipping fees and availability. I have a few broken screens, so I might just find what I'm looking for...
                                  Do you think these two coils are equivalent?
                                  • mon2
                                    • Dec 2019
                                    • 14342
                                    Yes. Just be sure to align the bottom side solder tabs / bar onto the PCB in the same direction as the original.
                                    • Christian0734
                                      • Nov 2020
                                      • 92
                                      • France
                                      Wow! Incredible, it works, I only replaced the one I took a photo of and I got the Backlight working on battery! Sincerely, thank you mcplslg123 et lundi2
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        I told you right from the beginning its weird but works.
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                        • user546087
                                          Keyboard backlight too bright - Asus Zenbook S16 / UM5606
                                          by user546087
                                          I have a new Asus Zenbook S16, Model UM5606. Unfortunately, the keyboard backlight is too bright, even on the lowest setting. I have explored several ways now:
                                          - kindly ask Asus for an adjustment - they basically told me to STFU and get lost It is not possible, they say. Of course.
                                          - tint the keycaps from behind - I have already tried that - it is kind of a last resort
                                          - try to find out, how it is done, look at schematics - this is, where we are at.
                                          - maybe get the BIOS modified somehow? This would be the best option but I do not know a lot about...
                                          02-24-2025, 02:03 AM
                                        • FallenOne008
                                          Asus G712L No Screen Backlight
                                          by FallenOne008
                                          Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
                                          The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
                                          03-31-2025, 08:27 PM
                                        • batalski
                                          Asus X541N works on charger but not battery
                                          by batalski
                                          When turned on with charger it works and shows battery 32%. But when power off it goes out. Does not charge battery.
                                          10-24-2022, 01:52 AM
                                        • Stephen
                                          A1466 MacBook Air 13" 2017 Backlight issue works but then turns off
                                          by Stephen
                                          Hello, got a weird MacBook Air here
                                          board looks fresh and no water damage, backlight works and turns on and stays on when installing OS etc. However, when the os is installed and when the system files are loaded before the login page the backlight goes out. I have wiped it, NVRAM reset, etc and even took some other instances and this blows my mind, never seen this before. Backlight just turns off once the OS is loaded. Anyone come across this and if so what would be the cause? I am certain its a board issue since I tested the LCD on another board and it stays on. Again the backlight works...
                                          08-23-2023, 09:12 AM
