Sony vaio SVS13A1S9ES no picture
  • lefos
    • Nov 2013
    • 321
    • Greece
    This one doesn't have picture on the lcd screen. With external monitor works perfectly. Fuses are OK and the cable seems OK too. The mainboard is MBX-259. Is it possible that the schematic diagram will be found?
  • PlusCom
    • May 2013
    • 50
    • Greece
    Re: Sony vaio SVS13A1S9ES no picture
    Try to reflow GPU.
      Can you see the screen glow in the dark room? May be the backlights (LEDs) are not on. I will not expect problem in GPU since you are able to get the image with external monitor.
      • lefos
        • Nov 2013
        • 321
        • Greece
        Thanks for your replies,
        Nope there is no picture at all (like you haven't connected the panel). There is a missing voltage 3.3V on the connector and I wanted to trace it..
        • robrock1
          • Jul 2013
          • 129
          • Ghana
          check if there is any small 5 or 6 pin ic around which switches the 3.3volts maybe it is damaged which can happen when you put the connector on the board while the machine is on.
          • lefos
            • Nov 2013
            • 321
            • Greece
            Thank you for your reply.
            Please check the photo. I think that without its schematic diagram I can't do anything right not. I have searched for it with no result.
            • dj_ricoh
              • 2073
              i see a jump wire!
              why you use it?
              it was a fuse?
              • lefos
                • Nov 2013
                • 321
                • Greece
                You got me there Yes that one was off but nothing changed.
                • PlusCom
                  • May 2013
                  • 50
                  • Greece
                  Getting image on external monitor doesn't mean that everything is ok with GPU. Today I had same situation again, laptop was working on external monitor only and after reflow it worked. So try to reflow it you have nothing to lose.
                  • lefos
                    • Nov 2013
                    • 321
                    • Greece
                    Thank you for your reply. The problem is not from the gpu. On older models the same thing happened to me once but on this one as I have previously said 3.3v don`t exist on the connector for the panel. Also after bridging that fuse picture on the panel came but after 10 minutes it disappeared. Can anyone provide me with the part number of those two 5 and 6 pins ics that are there please?
                      It blows the new fuse, so it means that the T-CON on the panel is drawing too much current due to bad components on the T-CON board.
                      • lefos
                        • Nov 2013
                        • 321
                        • Greece
                        Thanks for your reply. I am measuring on the mainboard side of the lvds connector with the panel disconnected so I guess the panel is OK. Also the fuse on the panel is OK..
                        • alihomee
                          • Dec 2012
                          • 1576
                          • malaysia
                          try with different cable
                          • spidey
                            climbs
                            • Dec 2012
                            • 644
                            • Cyprus
                            what is this 3.3v for ? did you check the voltage without plugging the connector ? try separating that pin from the connector and apply 3.3v externally(or from the mobo) and see if it worked.
                            • mitu_sharma
                              • Jul 2015
                              • 182
                              • india
                              check fuse near lvds conn. if all is ok then reflow gpu
                              • Chieftain
                                • May 2016
                                • 72
                                • Greece
                                what about if it is the version without extra GPU?
                                • KvnTM
                                  • May 2018
                                  • 434
                                  This thread is 4 years old. Open a new one
                                    Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                    This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    09-06-2024, 05:27 AM
                                    Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                                    This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
                                    Sony VAIO VPCM12M1E/W Netbook Specification for Upgrade or Repair
                                    This specification for the Sony VAIO VPCM12M1E/W Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VAIO VPCM12M1E/W boardview and VAIO VPCM12M1E/W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    Sony VAIO SVT1122I4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                                    This specification for the Sony VAIO SVT1122I4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVT1122I4E boardview and SVT1122I4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  • Carlos#2003%
                                    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                    by Carlos#2003%
                                    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                    02-15-2024, 07:52 PM
