Aspire z5700: No Backlight
  • speedypro
    • Feb 2013
    • 561
    I got this i3 all in one computer desktop for repair.
    It has no backlight. Changed inverter and same issue. If I removed any one of the four plugs on the inverter, the backlight comes on at startup but just for few seconds. These plugs are for the lamp (backlight).
    Board issue anyone?
    Board model: DAOEL5MB6E0. Also I may have post this in the wrong section.
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • dj_ricoh
    • 2073
    • uk
    Re: Aspire z5700: No Backlight
    speedypro i3 with normal lcd screen like inverter?
    if yes try a smash screen like just connect it to the inverter and let the original with video cable on
    • speedypro
      • Feb 2013
      • 561
      I'll try that. Thanks.
      • robrock1
        • Jul 2013
        • 129
        • Ghana
        check if brightness and power on signal is stable (3.3v or similiar) at the inverter, if its ok, resolder inverter coil and transistors. connect known good lamps and try. reduce the brightness.
        • speedypro
          • Feb 2013
          • 561
          Nothing to do with inverter as we've tried another one. This other inverter was bought off ebay, so how knows if its working lol
          • dj_ricoh
            • 2073
            • uk
            just try a smash screen and see if it lights up.
            i made today like 3 ; same thing.
            if there is no backlight on lcd with lamp i`ll fix it.
            i got 30kg of smash screens
            • speedypro
              • Feb 2013
              • 561
              I have yet to try one as yet. But if I remove one of the lamp connection off the inverter, it lights up for few seconds then gone. The inverter has four lamp connectors. When all four are connected, no light.
              • dj_ricoh
                • 2073
                • uk
                i just saw the pics on google.
                you need to be on lcd monitor section.
                try to find some spare lamps from broken screen like salvage and test like here:
                http://www.youtube.com/watch?v=eORAoaWpqao
                see if you got a lamp on your screen that has fail.
                top or bottom
                • spidey
                  climbs
                  • Dec 2012
                  • 644
                  • Cyprus
                  you have a bad solder connection to ccfl or one of the lamp is bad. Unassamble the screen and check the lamps.
                  • Cornito
                    Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
                    by Cornito
                    Hello Team,
                    I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
                    Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
                    Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
                    08-08-2024, 08:09 AM
                  • cheebster
                    iPad Pro 12.9 5th Gen Backlight Issue
                    by cheebster
                    Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                    Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                    Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                    The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                    Anyone...
                    05-20-2025, 09:17 AM
                  • Cornito
                    TCL 65C715 backlight issue
                    by Cornito
                    Hello team,
                    I'm back with another topic.
                    It's a 65C715 TCL tv with backlight issue.
                    But the problem is a bit strange.
                    When I took this tv from the marketplace backlight didn't work but picture was ok.
                    Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
                    Putting all back together the tv worked fine for weeks. => Contact issue??
                    Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
                    06-09-2024, 02:24 AM
                    ACER Aspire Aspire X3910 Aspire E5700 Specification for Upgrade or Repair
                    This specification for the ACER Aspire Aspire X3910 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X3910 boardview and Aspire Aspire X3910 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                    09-12-2024, 03:36 PM
                    ACER Aspire Aspire XC-886 Aspire XC i5-9400 Specification for Upgrade or Repair
                    This specification for the ACER Aspire Aspire XC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-886 boardview and Aspire Aspire XC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-12-2024, 03:30 PM
