P71EN0 REV. C no power on
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    if consider power sequence, i have +3VA +5VA +12VA, when press power on button i am unable to get +3.3VS_ON and +3,3 VA and +5VA go to 0V
    any help?
  • Francisco.s
    • 685
    • Spain
    Re: P71EN0 REV. C no power on
    any help?
    Check CPU_CORE (pin 2 of L2 coil) for short-circuit (any value above 1 ohm is ok), also check other pwm coils for low resistance.
    Could you check current consumption from 19 volts?
    Are 19 volts stable when you press power button?
    Post results.
    Good luck.
    • Pragmatiko
      • Jul 2013
      • 468
      • IT
      Tomorrow i'll post results.
      Thank you very much.
      • Pragmatiko
        • Jul 2013
        • 468
        • IT
        Post results.
        Good luck.
        suddenly worked but after some time i test it now defective again
        • Pragmatiko
          • Jul 2013
          • 468
          • IT
          i am thinking about bad contact under CPU soket, what do you think?
          • Pragmatiko
            • Jul 2013
            • 468
            • IT
            when turn on CPU_CORE is 0,7volt
            • dj_ricoh
              • 2073
              • uk
              do the board a favor and make a cake
              stick it in the oven
              • infosquadsn
                • Nov 2013
                • Argentina
                ICH is a master piece on the power sequence. Try to apply a moderate heat in the south bridge for approximately 30 seconds using a heat gun or a SMD rework station. If after the test the laptop works again.....reballing it.
                sorry the poor english and good luck
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • GLISIT
                  by GLISIT
                  01-16-2025, 02:29 PM
                • PantherDave
                  by PantherDave
                  Hi all!
                  05-29-2024, 02:01 PM
                  03-31-2024, 02:12 PM
                  09-06-2024, 05:59 AM
