macbook a1181
  • crazypepe
    • Oct 2012
    • 34
    • Philippines
    macbook a1181
    hi guys
    got a macbook a1181 that has no power no green led from charger
    after disassembly power has returned with green led from charger
    but after assembly and a day or two there will be no power again
    it happened like three times already it always goes back to no power after a day or two
    mobo has no short
    not overheating
    battery and charger is new
    pls help dont know what the problem is
    actually i have another one that has the same problem but it is an acer extensa 5635
  • lord
    • May 2011
    • 319
    • Croatia
    Re: macbook a1181
    It sounds to me like a cold joint somewhere on power circuit. Had a few with same problem.
    • crazypepe
      • Oct 2012
      • 34
      • Philippines
      Re: macbook a1181
      wow ill definitely check on that one
      never thought that a cold joint could happen on a never been repaired laptop
      thank you so much for the reply lord
      • ielektros
        • Aug 2013
        Re: macbook a1181
        Have you found some solution? I have the same problem.
