BD82HM55 to replace BD82PM55 PCH Chip
  • whaldsz
    • Apr 2013
    • 395
    • Philippines
    Has anyone tried to replace BD82PM55 with BD82HM55 PCH chip with success?
    I'm working on a motherboard (Lenovo Y550P with Intel Core i7-720QM processor, see here for detailed specs).
  • Learn2Day
    • Jun 2013
    • 254
    • Portugal
    Re: BD82HM55 to replace BD82PM55 PCH Chip
    Apparently they are compatible.
    http://www.alibaba.com/product-gs/68..._CHIP_FOR.html
    They're selling BD82HM55 to replace both.
    Cheers.
    Galaxy S6 Edge x2 (Gold&White)
    Asus GL552VW-i7 6700HQ|GTX 960M|15.6"FHD|16GB DDR4|512GB M.2 SSD+1TB SSD
    Clevo W230SD - i7 4710MQ|GTX960M|13"QHD+|16GB DDR3L|500GB+256GB mSATA SSD+1TB HDD
    Try Harder!
    • whaldsz
      • Apr 2013
      • 395
      • Philippines
      That's great news!
      • lord
        • May 2011
        • 319
        • Croatia
        Please post results!
        • DynaxSC
          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
          by DynaxSC
          Hi
          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
          08-04-2025, 12:20 PM
          Common SPI bios chip programming Questions and Answers
          by SMDFlea
          Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
          A: If you can`t read from it how do you expect to write to it ?.
          Q: Why is my bios chip unreadable ?.
          A: The programmer is faulty or has a worn or broken zif socket.
          The USB cable is frayed,connector pins worn or some other physical damage.
          Not enough amperage or voltage to power the programmer properly.
          Bad...
          09-02-2021, 04:40 PM
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • elzorroazul777
          Did I Screw Up? Any Hope for Success? Programming BIOS CHIP
          by elzorroazul777
          Before I go further down the rabbit hole, I'd like to know if I have created a dead-end in my repair process. I am attempting to reflash my Lenovo X1 Extreme Gen 2's BIOS chip after a power interruption corrupted the BIOS data during an update.
          I do not have backups of the data I pulled off the chip using a CH341A 24 25 Series EEPROM https://www.amazon.com/Organizer-Soc...Q%3D%3D&sr=8-5
          I also wrote to the...
          10-09-2022, 10:45 AM
        • Jeroentje
          Asus X571GT repair chip replace and tips wanted
          by Jeroentje
          Hi
          I try to repair a asus Asus X571GT (DA0XKTMB8C0) no power no lights.
          I saw a burned (small hole in it) chip (JW10F) proberly a TPS22976DPUR, I removed it, now with power connected the laptop turns on and direct off again, power led and fn will light up.
          I found on a donor lenovo board a G2898KD1U (wa9y), looks the same ..
          Result is still the same, turns on and direct off again, first attempt is with backlight on all other direct attempts are only the power and fn led.
          Could it be the chip is to diffrent to make the laptop work again ?
          04-28-2024, 10:59 AM
