Need replacement SATA connector for Toshiba C665
  • inflex
    • Aug 2012
    • 545
    Client handed me a well broken laptop, screen smashed, keys missing, etc - all which I can sort out, *except*, they also managed to smash the SATA HDD connector on the mainboard
    I've managed to remove the broken unit, ready to accept a new one, but alas it seems to be a case of I have to get it from amother C665 or throw the whole damned thing out, as I cannot find anything on the general electronics parts suppliers which matches, the problem is made worse by the fact that this is a fairly precision alignment setup, so +/-0.5mm in height or position will render it useless.
    So....anyone got a spare one? Obviously happy to pay freight/costs.
    ** The unbroken picture is just for reference, this was off another client laptop that happened to come in a few days later that was of the same model.
    YouTube Repair Videos - https://www.youtube.com/user/19PLD73
    FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
  • inflex
    • Aug 2012
    • 545
    Re: Need replacement SATA connector for Toshiba C665
    Bump? Anyone?
    • Tomylee
      No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
      by Tomylee
      Sorry for the person who’s going to read all this !
      I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
      While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
      During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
      07-11-2025, 11:52 AM
    • DynaxSC
      GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
      by DynaxSC
      I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
      There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
      The board is generally working now, all PCIe ports are working, Windows installs normally.
      However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
      The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
      03-10-2025, 12:27 PM
    • michhak
      Toshiba Satellite M50-A keyboard connector on LA-A481P motherboard
      by michhak
      Hi guys,
      i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
      It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector...
      11-17-2021, 05:45 AM
      09-06-2024, 05:59 AM
