sony vaio SVE151J13M
  • dj_ricoh
    • 2073
    • uk
    hy guys!
    i`m working on a sony not a old model.
    MB model da0hk5mb6f0 mbx-269 REV: F (i got NO schematics)
    The problem is : power on for 2-3 sec then shutdown all led near power button blink at that time then off.
    the first think i poke around was the ISL88731
    got 3.3v on power button.
    VCC - 5.03V PIN26
    DCIN -18.5V PIN22
    VDDP - 5.04V PIN21
    ACIN - 3.47V PIN2
    VREF - 3.19V PIN3
    ACOK - 4.63V PIN13
    any idea its welcome
    ty
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: sony vaio SVE151J13M
    with the measurements you got, it looks it is operational. start with this schematic.
    • dj_ricoh
      • 2073
      • uk
      i hate this type of fault when everything its there but it who work
      • dj_ricoh
        • 2073
        • uk
        i did a reflow it power up but no img , after that got the same sympth power up for 2 sec then off
        any advice?
        • Francisco.s
          • 686
          • Spain
          any advice?
          Check pin 8 (ICM) of IC ISL88731. It controls the current consumption.
          • lord
            • May 2011
            • 319
            • Croatia
            Do you have a BIOS dump for this board maybe?
            • lord
              • May 2011
              • 319
              • Croatia
              Anybody?
              • ghojariya abdul
                • Jul 2014
                • 39
                • india
                hi guys
                i had diferrent prob.same laptop in my case display become dull
                i had check fuse near lvds conector its open ihad change the fuse but prob. is steel ther.
                please help ....
                • atsio
                  • Oct 2013
                  • 819
                  • Greece
                  Replace the panel
                  • hansie55
                    • Dec 2013
                    • 254
                    • Netherlands
                    hy guys!
                    VCC - 5.03V PIN26
                    DCIN -18.5V PIN22
                    VDDP - 5.04V PIN21
                    ACIN - 3.47V PIN2
                    VREF - 3.19V PIN3
                    ACOK - 4.63V PIN13
                    ty
                    You know I do not have the knowledge to help you out, but I can send you more schematics
                    • dj_ricoh
                      • 2073
                      • uk
                      I got like 3 notebooks like this same crap.
                      only one there was a lcd connector on the board with bend pin that when I power it up I think something burn.
                      with the one from the first post I wont even touch it without a bga station.
                      • hansie55
                        • Dec 2013
                        • 254
                        • Netherlands
                        I can imagine the situation, you know my laptops and I have some more to do as well.
                        Mostly Toshiba. I finally got the Ene chip today to fix the Packard Bell from some weeks ago.You saw the disaster. Then there is of course still the Sony, which I would like for myself. Finally a decent laptop and I can't get him fixed and no schematics,
                        But lets keep a good faith and fix the basterds.
                        • Tekno
                          • Oct 2013
                          • 18
                          replace PCH
                          • lorenzo91
                            • Sep 2014
                            • 5
                            • San Marino
                            i have fixed 1 board with your dump MBX_269.rar
                            • dj_ricoh
                              • 2073
                              • uk
                              power up after 2 sec off?
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3592
                                • slovakia
                                power up and die it will be a power switched rail problem. chceck all big coils for voltage rise. if some coil voltage dont rising there could be problem
                                • highpulse
                                  i hate HP
                                  • May 2013
                                  • 1488
                                  • portugal
                                  well mine doing the same , but a store delivered it to me saying it was not displaying imaeg , but all the time i press it light up then fade out after 2 or 3 sec
                                  tryed insertnig a new dump , but gives always error in the end !
                                  • highpulse
                                    i hate HP
                                    • May 2013
                                    • 1488
                                    • portugal
                                    ok fixed , with the dump ,
                                    something strange usually before reprograming the mchien erase the chip then it programa , but like this was giving adressing error on the end .
                                    so i tryed erasing first the chip , and then presing program , and it sucessfuly worked out , installed the rom on board and its working now
                                    another one solved , thk fr the share guys
                                    • Ramee
                                      • Jul 2014
                                      • 218
                                      • Israel
                                      Nice one.
                                      Before i forgot, i need WPCE775LA0DG datasheets, may be you got one there
                                      I tried google but no luck
                                      • highpulse
                                        i hate HP
                                        • May 2013
                                        • 1488
                                        • portugal
                                        well
                                        any a300 schematic
                                        tells you pinout for it
                                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
                                          Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                                          This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
                                          Sony VAIO VPCM12M1E/W Netbook Specification for Upgrade or Repair
                                          This specification for the Sony VAIO VPCM12M1E/W Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VAIO VPCM12M1E/W boardview and VAIO VPCM12M1E/W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          Sony VAIO SVT1122I4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVT1122I4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVT1122I4E boardview and SVT1122I4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
