Dell inspiron 1564. no display
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    good day to all...
    i have a dell inspiron 1564. have no display..
    I try to remove and install Ram and i Used another Good Tested One Same as Problem...not luck
    I Disassemble the unit... I See if I Press the power on the System Board have power have Light indicate also. if i Press The on/off Button can Off also.
    I observe The Fan of CPU has not Spinning. I check The Fan to other Unit Fan Are Working. I replace a new working Same As Problem..
    Can you Help me to Solve This Problem in My Dell Inspiron 1564.
  • dj_ricoh
    • 2073
    • uk
    Re: Dell inspiron 1564. no display
    write down the model of the board and some pic of the board
    • TheQuentincc
      Dell XPS 9300 (LA-H811P) internal display only shows Dell logo then nothing (everything else works)
      by TheQuentincc
      I have a Dell XPS 9300 that's working perfectly fine with an external display plugged, from windows the internal display isn't detected. At boot I can see the Dell logo then when it should display the boot/bios or whatever the screen goes black (no backlight, no image using a flashlight). I tried unplugging everything on the motherboard except the eDP cable but it didn't helped (so it's not the lid sensor). LCDVDD/backlight power are powered down when this happen, PANEL_BKEN_EC and ENVDD_PCH are also down to 0v. It's weird, it almost feels like the motherboard is shutting down the display...
      06-26-2025, 01:44 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
      Dell Inspiron 1464 1564 1764 UM3B Boardview
      Dell Inspiron 1464 1564 1764 UM3B Boardview...
      10-22-2024, 02:37 AM
      DELL Inspiron 7586 Hybrid (2-in-1) 7000 Specification for Upgrade or Repair
      This specification for the DELL Inspiron 7586 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7586 boardview and 7586 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron...
      09-06-2024, 07:11 AM
      DELL Inspiron 3780 Notebook 3000 Specification for Upgrade or Repair
      This specification for the DELL Inspiron 3780 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3780 boardview and 3780 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 3780...
      09-06-2024, 08:20 AM
