Toshiba l40 18w not working
  • innocentforeign
    innocentforeign
    • Jun 2013
    • 172
    • KSA
    HI
    every one i got a toshiba machine form customer , he say laptop fan was close from 2 days and now machine not working . i check it and open machine north bridge side was full from paste now just charger lEd working 2.1 volt coming at power button please help
  • DJduck
    • Dec 2012
    • 229
    • Estonia
    Re: Toshiba l40 18w not working
    "he say laptop fan was close from 2 days". Do you mean that the fan did not run for two days? If so, you probably have a fried cpu/gpu/chipset/mosfets under the heatsink/all of those problems.
    I can put text here?!
    • innocentforeign
      innocentforeign
      • Jun 2013
      • 172
      • KSA
      yes but he use extrnal fan after open i saw fan was full from dust
      now how can i fix this problem
      • DJduck
        • Dec 2012
        • 229
        • Estonia
        Try a different CPU, reflow the GPU and chipset.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Likely killed the heatsinked part(s).
          Even using an external fan, if the heatsink is plugged with dust, you will get a fried chip...
          Muh-soggy-knee
          • innocentforeign
            innocentforeign
            • Jun 2013
            • 172
            • KSA
            thanks
            after change cpu bord working now display not coming caps lock num lock not working i reflow gpu but same problem no display
            • innocentforeign
              innocentforeign
              • Jun 2013
              • 172
              • KSA
              any idea how to fix it
              • Soulzink
                Samsug washing machine. Power supply DC41-00189a board issue
                by Soulzink
                I am trying to fix a samsung washinmachine power supply main board.
                I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                The power supply board reference is the following: DC41-00189a
                I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                04-19-2025, 06:26 AM
                09-06-2024, 05:27 AM
              • MMH3
                Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                by MMH3
                i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                Never ever i experienced problems with that.
                Now i have one 5050sff machine, where this jumper isnt working at all.
                I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                The history of the machine is that i used it in my office...
                03-23-2025, 09:28 PM
              • DynaxSC
                GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                by DynaxSC
                I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                The board is generally working now, all PCIe ports are working, Windows installs normally.
                However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                03-10-2025, 12:27 PM
              • obelix24
                Macbook Air 2020 (a2179) - touch id not working
                by obelix24
                Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
                I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
                02-09-2025, 12:57 PM
