Toshiba l40 18w not working
  • innocentforeign
    innocentforeign
    • Jun 2013
    • 172
    • KSA
    HI
    every one i got a toshiba machine form customer , he say laptop fan was close from 2 days and now machine not working . i check it and open machine north bridge side was full from paste now just charger lEd working 2.1 volt coming at power button please help
  • DJduck
    • Dec 2012
    • 229
    • Estonia
    Re: Toshiba l40 18w not working
    "he say laptop fan was close from 2 days". Do you mean that the fan did not run for two days? If so, you probably have a fried cpu/gpu/chipset/mosfets under the heatsink/all of those problems.
    I can put text here?!
    • innocentforeign
      innocentforeign
      • Jun 2013
      • 172
      • KSA
      yes but he use extrnal fan after open i saw fan was full from dust
      now how can i fix this problem
      • DJduck
        • Dec 2012
        • 229
        • Estonia
        Try a different CPU, reflow the GPU and chipset.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Likely killed the heatsinked part(s).
          Even using an external fan, if the heatsink is plugged with dust, you will get a fried chip...
          Muh-soggy-knee
          • innocentforeign
            innocentforeign
            • Jun 2013
            • 172
            • KSA
            thanks
            after change cpu bord working now display not coming caps lock num lock not working i reflow gpu but same problem no display
            • innocentforeign
              innocentforeign
              • Jun 2013
              • 172
              • KSA
              any idea how to fix it
              • alpersen
                Siemens Washing Machine WM12T581TR/67 Touch Panel not working correctly
                by alpersen
                On the right bottom side it has a start/stop button (normally it is illuminated, when I took the picture it was blinking I took at the wrong time ). and the touch area there is not working, maybe if I am able to touch the most right bottom in a maybe 1 square millimeter area it works. also generally if I touch the normal place where the start stop icon is, the weight + and - areas register so there is a touch calibration problem in that area. All icons maybe 60% of the left side register correctly in their respective size. Siemens service recommends replacing the control pcb and screen (nearly...
                10-24-2025, 01:55 AM
              • TyMercer
                Can I flash a working BIOS from one computer to another of the same make, model, etc?
                by TyMercer
                Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
                Yesterday, 09:39 PM
              • Soulzink
                Samsug washing machine. Power supply DC41-00189a board issue
                by Soulzink
                I am trying to fix a samsung washinmachine power supply main board.
                I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                The power supply board reference is the following: DC41-00189a
                I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                04-19-2025, 06:26 AM
                09-06-2024, 05:27 AM
              • MMH3
                Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                by MMH3
                i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                Never ever i experienced problems with that.
                Now i have one 5050sff machine, where this jumper isnt working at all.
                I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                The history of the machine is that i used it in my office...
                03-23-2025, 09:28 PM
