NP530U3C water damage
  • Learn2Day
    • Jun 2013
    • 254
    • Portugal
    hi.
    i have a Samsung NP530U3C with water damage, i've cleaned it up nicely with kontack spray, got no burn or moist marks, but the laptop still only powers up power led and nothing else, no screen, no hdd, nothing. i've browsed the internet for schematics and service manuals but came up empty. Any ideas?
    Thanks in advance.
    Galaxy S6 Edge x2 (Gold&White)
    Asus GL552VW-i7 6700HQ|GTX 960M|15.6"FHD|16GB DDR4|512GB M.2 SSD+1TB SSD
    Clevo W230SD - i7 4710MQ|GTX960M|13"QHD+|16GB DDR3L|500GB+256GB mSATA SSD+1TB HDD
    Try Harder!
  • Francisco.s
    • 686
    • Spain
    Re: NP530U3C water damage
    verify voltage in power button, and if go to zero when pressed.
    • spidey
      climbs
      • Dec 2012
      • 644
      • Cyprus
      measure current on standby and after pressing power on.
      • edugimeno
        Stagg sms12p audio amp has water damage
        by edugimeno
        Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
        I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
        There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
        There is only one signal wire connecting the first boards...
        05-24-2025, 06:00 AM
      • Joel Ohana
        Lenovo IdeaPad 3 15IAU7 that suffered water damage
        by Joel Ohana
        I have a Lenovo IdeaPad 3 15IAU7 that suffered water damage. It doesn't turn on (white power light flashes when on button pressed), and the amber light flashes when plugged in.
        Symptoms:
        • Short detected – sparks appear when touching the charging port connection with board with a metal (even a multimeter probe).
        • Visible damage – after cleaning corrosion, I found 4 possibly burnt memory chips near PC3165, labeled UD5, UD6, UD7, and UD8.
        What are my next steps to diagnose and possibly repair it without replacing the entire board? Any guidance would be greatly...
        03-06-2025, 11:25 AM
      • abajor
        A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
        by abajor
        Like title says A2141 came in with Water Damage, customer desperately wants the data.
        The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
        I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
        That said after cleaning up the...
        12-21-2024, 07:16 PM
      • s_henya
        Macbook Air A3114 5V 0.0A after water damage
        by s_henya
        Hi Mac experts :-)
        Im usually not getting too many Mac logic boards repairs, (mostly PC laptops)
        This Mac isn't powering on not boosting to 20v, stays at 5v with 0.0Amps.
        Took out the board and it suffered some water damage, see attached pics.
        All cleaned with IPA but due to long time with corrosion something already got shorted...
        any advice on the below:?
        1. Looking for relatively safe location for voltage injection as all of the caps around that area has 0.0ohms resistance.
        I tried injecting 0.5v on one of the caps...
        Today, 01:09 PM
      • rtstorm
        HP EliteBook 840 G8 water damage - identify component
        by rtstorm
        Hello, i got an HP EliteBook 840 G8 that has water damage, and i found this component has damage on it U60600. What is that component? I have schematics and boardview and the par no is:
        SINERGY_SYV128RAC_QFN_20P i cannot fount it anywhere. Is this component have some other name?
        Here is schematics + boardview...
        09-18-2024, 05:36 PM
