no power
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    no power
    anyone has schematic of this netbook?
    Asus Eee PC 1001P
    pls help
    thanks
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: no power
    need motherboard code..
    • whaldsz
      • Apr 2013
      • 395
      • Philippines
      Re: no power
      Not sure if this is what you are looking for.
      • fddizon
        • Sep 2011
        • 555
        • Philippines
        Re: no power
        thanks bro.
        it matched the net book I'm working on.
        adapter LED blinks continuously when charger plugged in.
        i have replaced EB24B03G chip and one shorted ceramic capacitor. the blinking went away but still the laptop doesn't power on. no standby power.
        have you encounter the same trouble?
        thanks kabayan
        • whaldsz
          • Apr 2013
          • 395
          • Philippines
          Re: no power
          Haven't had a chance with ASUS motherboard. The power sequence on page 2 of the schematic could be helpful though.
          (I knew edgar, cris and michelle from your workplace)
          • fddizon
            • Sep 2011
            • 555
            • Philippines
            Re: no power
            we have 2 edgar, macaraeg and someone from college of technolgy
            michelle subiate
            and chris taguines
            • whaldsz
              • Apr 2013
              • 395
              • Philippines
              Re: no power
              edgar macaraeg and michelle, and chris flora was my classmate way back msit days at neust.
              • xe_d_sono
                • Aug 2013
                • 25
                • Portugal
                Re: no power
                Originally posted by fddizon
                thanks bro.
                thanks kabayan
                Can you say what capacitor did you change?
                • fddizon
                  • Sep 2011
                  • 555
                  • Philippines
                  Re: no power
                  the one in between USB and fan
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • ShadowAi
                    ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                    by ShadowAi
                    Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                    Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                    After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                    03-15-2024, 10:46 AM
                  • meraklinetx
                    Asus Z97-a power cycle, no boot no cpu voltage
                    by meraklinetx
                    Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                    05-10-2023, 06:08 AM
