Lenovo E520 Backlight Problem..
  • wainy54
    • Jun 2013
    • 4
    • United Kingdom
    Hi All,
    I'm attempting to repair my Lenovo E520 laptop. It suffered a small fall, which shattered the LCD. I've managed to replace this, however the backlight isn't working. Annoyingly its not just a bad screen, seems like a mainboard issue.
    After a bit of digging, looks like there are two fuses on the board that may have failed. I'm looking to swap or short these out. Found some info on this polish forum.
    http://www.elvikom.pl/forum/viewtopi...839&view=print
    I found markings for the fuses in question (F4901 & F4903), however I'm not certain which SMD are the fuses. See this pic (sorry cant seem to embed it):
    https://www.dropbox.com/s/ijl7h52l60...2-15-14-41.png
    Could anyone offer any help identifying the fuses?
    Wainy
  • trebo
    • 514
    • Wales, UK
    Re: Lenovo E520 Backlight Problem..
    Originally posted by wainy54
    Hi All,
    Wainy
    fuse above "f4" of f4903
    and other fuse above "90" of f4901, in your picture
    • wainy54
      • Jun 2013
      • 4
      • United Kingdom
      Thanks. I've just tested F4903 (above "F4") and that seems intact with continuity. F4901 appears to be the problem, I will treat this to a blob of solder sometime tomorrow. Wish I could replace it, but I simply don't have the equipment and its just so tiny....
      I will give it a go and report back.
      Thanks again.
      • wainy54
        • Jun 2013
        • 4
        • United Kingdom
        Thanks again trebo, I removed the blown fuse and soldered in a small length of jumper wire. It was a bit of a battle, due to the size of the fuse and my relatively huge soldering iron tip (maybe time to spend some £££) but managed it in the end.
        Now I'm glad to report the laptop is working once again.
        Wainy
        • usman1972
          • Mar 2015
          • united kingdom
          Wainy
          Many Thanks
          it work for me too it was fuse above F4901 the middle one just jumper with wire don't have to remove just jumper it.
          • ncdave
            • Oct 2003
            • 33
            wainy54, trebo & usman1972, you saved me! I was at my wit's end.
            The culprit on mine was F4901, too. Unlike yours, mine was marked with a tiny "3" which could be read with a jeweler's lupe. (The other two fuses, F4902 & F4903, were marked F and G, and were not as tiny.)
            I think that's the tiniest thing I've ever successfully soldered. Wow, that was hard.
            This is my magnifying glass kludge (my biggest magnifying glass lashed to a gooseneck lamp to hold it in place):
            http://www.geeksalive.com/magnifying...E520_25pct.jpg
            Here's a closeup of the F4901 (culprit) fuse location:
            http://www.geeksalive.com/Lenovo_E52...it_closeup.png
            Here's the full-sized photo of the F4901 fuse location:
            http://www.geeksalive.com/Lenovo_E52...ad_culprit.jpg
            Does anyone know where to get those clamp-on-your-glasses binocular magnifiers which the dentists use? I need a pair!
            I also need to get a soldering iron with a shorter tip-to-grip length. It was really difficult to keep the tip of my trusty 50yo Ungar steady enough to solder that tiny fuse. Does anyone have a recommendation?
            Has anyone tried the Pro'sKit SI-B161 battery-operated 9W soldering pencil? In the photos, it looks like it has a pretty short tip-to-grip length, unless the black part near the front gets too hot to hold.
            • tibimakai
              • Jan 2012
              • 3680
              ncdave, what was your problem with the laptop?
              • dlshad96
                • Apr 2016
                • 39
                • Us
                Originally posted by usman1972
                Many Thanks
                Hello Guys
                i have same laptop Thinkpad E520 yes its the fuse problem the lite back but no data the screen now is white the led working but no data . before was black screen working with only external screen.
                working with external monitor fine , i change the internal led screen its same no data change the cable same problem
                testing the screen with another laptop the screen working well.
                could you please helping me whats the correct part i have to replace it.
                Thank you in advance.
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  Many Thanks
                  Where to make a jumper wire can you show a photo please
                  • ravi_1617
                    Lenovo B540 ,Starting Problem
                    by ravi_1617
                    Hello !
                    Model Lenovo B540
                    Board Details 09244-1
                    LA14 DIS MB
                    48.4DMO4.01.1
                    This Board has starting problem , when CMOS batter is removed ,it starts (turn ON) by itself fine, than if is short power switch once board turns OFF Fine.
                    when connected CMOS dont start.
                    3.3 volts present at power switch (it slight less 3.267-87) .there was slight liquid spill at around U53 (SL62872HR),when I clean that area . I mean when its little hot board warm , board starts few time ON and OFF by power switch
                    One more thing i want to mention ( by mistake i started at...
                    10-14-2025, 02:08 AM
                  • lucaszmn
                    by lucaszmn
                    Problem:
                    Initial Findings:
                    • I concluded that the
                    08-12-2025, 03:01 PM
                  • coasterghost
                    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                    by coasterghost
                    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                    System Hardware:
                    Processor: AMD Ryzen 7 PRO 5850U
                    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                    09-08-2025, 10:46 PM
                  • eric35
                    Problem backlight lenovo s145-15ast
                    by eric35
                    Hello ,
                    I have Problem of backlight on my lenovo s145-15ast.
                    I touched the lvds connector with the cable.
                    it sparked and now my screen is very dark.
                    I tested the f2 fuse and it seems good. it beeps with my multimeter in continuity mode.
                    04-18-2023, 10:47 AM
                  • s_specialist
                    Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
                    by s_specialist
                    Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
                    07-07-2025, 11:47 AM
