fujitso ah530 no power
  • mrfelc
    • May 2013
    • 8
    • iraq
    lifebook ah530/hd6 no power please help
  • jtamad44
    • Apr 2013
    • 145
    • israel
    Re: fujitso ah530 no power
    check the power supply first, memory. cmos battery. check for 3.3, 5 and 12 voltz on board, flash or replace bios chip. look for burnt components, things like that..
    • mrfelc
      • May 2013
      • 8
      • iraq
      no 3.3v no 5v and no 12v only adapter votage is ok
      power mosfet cheked and ok what chip that change?
      tanks
      • jtamad44
        • Apr 2013
        • 145
        • israel
        there is some coil around the dc jack check those. 3, 5 12 voltz you have find on board.. need a diagram for your mainboard.. i hope someone can give you a hand, i'm not that good when it comes to board..
        • mrfelc
          • May 2013
          • 8
          • iraq
          coil cheked...
          not any voltage only 19v on mosfet drain
          tanks
          • spidey
            climbs
            • Dec 2012
            • 648
            • Cyprus
            first of all, find a dump and flash your bios. what is the model of your mother board ? lets find the schematics. then we will maintenence on your board.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
              03-31-2024, 02:12 PM
            • bytefarmer
              Fujitsu Lifebook Power IC gets hot
              by bytefarmer
              I'm brand new to the forum. I've found this site because I have a very similar problem like this guy. It's also a Fujitsu Lifebook and has the same symptoms: LEDs briefly flash when connecting the power adapter, battery doesn't charge. Same behaviour when connection 14.4V to the battery pins.
              I have 0 experience with motherboards but I do have an electronics background, I am an electronic engineer but I have to say there's some dust on that knowledge although I play with Arduino's from time to time.
              I was measuring the mosfets like the other post and when...
              08-12-2024, 10:09 AM
